nice ride man... how was putting the SR20 in it?
Hey, this is my car, the pics are pretty self explanitary :2thumbs:
Mine's the Blue One
[attachment=22656:mod___st...ol_front.JPG]
S14 NA SR20
[attachment=22657:mod_engine.JPG]
Hilux Brakes
[attachment=22658:mod_brake.jpg]
Fuel System
[attachment=22659:mod_boot_2.jpg]
wasnt to difficult, took a while though.
Hey, do you have any photos of the SR20 transplant in the process?
Or would you be able to do a big writeup on it listing parts etc?
Im sure there are others but i cant find any.
this looks like it would an absolute sleeper!
No, you dont see rust that stuff in the boot is the backing from that crappy lining that KE70's have in the boot, this car has no rust & had only done 104500kms when I bought it
About the write up, I havent got any progress photos but I'll do a write up on everything I did, parts used, etc. Just give me a couple of days cause I just moved house and I gotta find the book I made up with all the specs. I will do it but.
Also, doin some more mods in the next few weeks so stay tuned.
That's one of the coolest sleepers I've seen! Very nice, conversion looks very pro
Driver of the yellow ae86
http://www.ae86drivingclub.com.au/fo...hlight=custard
Specs
Chassis: KE70 Sedan
Mods:
Enlarged Tunnel
G/Box hole 80mm back to accomidate nissan box
firewall behind back seats as per engineers instruction
rear suspension towers now in boot area
corolla engine mounts cut of cross member and welded back on to suit SR20
RX7 series 2 rubber engine mounts
Engine & Driveline:
N/A SR20 out of S14 silvia (VVT model, purchased from just jap)
S13 silvia turbo G/Box
ST165 Radiator
Custom catch can
T Series diff out of RA60 Celica with hieght adjustable spring mounts welded on
tailshaft made to suit by Hardie Spicer in Moorebank
2.5' exhaust to cat made by me and dad
2' cat back exhaust by penrith city exhausts
Suspension:
XT130 Corona front struts & hubs
struts shortened to suit SV21 Camry inserts
Noltec bushes throughout
Noltec weld on hieght adjusters in front & rear
AE86 sway bars front & rear
commodore rear shocks
Noltec adjustable panard bar
350lb King Springs front
200lb king springs rear
Noltec Camber adjusters
Brakes:
4 spot hilux 4WD calipers front
Corolla booster modified to suit toyota 4 stud master
MA61 supra master cylinder (15/16)
Peugeot 604 Front rotors
RA60 celica rear drums
Fuel System:
Custom 5/16 steel fuel lines under car
twin VL pumps
VL in tank Pump
Custom surge tank
Mitsibishi unleaded filler neck
Interior/exterior:
corona internally adjustable mirrors
tacho dash with VDO electronic speedo
Datto ute gear knob
Modified RA60 celica seats
Wheels:
XT130 14x5.5' wheels with 175/55/14 tyres
Coming Mods:
Konig rewind 15x7' rims
TRD 2way LSD to suit late model sprinter axles
rear disks
re-do rear suspension
re-do tunnel
boot mounted battery
2.2L stroker kit
Greddy winged sump
oil cooler
remote oil filter
a few body braces
Quad throttle bodies
extractors
new cams
adjustable cam gears
SR20 turbo injectors
new computer
chrome bumpers (in progress)
paint (black, same blue, white, gunmetal grey or charger orange)
Retrim (black leather)
Roll cage (maybe)
Fix damn front end shake (I cant find this stupid vibration so if anybody has any idea what it is I'll be glad to hear you suggestions)
So far all the work has been done by my Dad and Myself, exluding the tailshaft, exhaust & wiring so if anyone has any questions I should be able to answer them
Wiring:
Sideshow's Perfomance Wiring, Ask For Jim 0415 904 947
Tailshaft:
Hardie Spicer, (02) 9600 6333
Good work man that looks sick im currently putting an sr20det in my hachi ill get a few pics up when the conversion is a bit further along.
