Results 1 to 8 of 8
Thread: Alternator Help!!
    Veteran svenmate's Avatar
    Svenbot
    East
    Default Alternator Help!!
    hey all
    i figured the hard way that there are two types of alternators for the 4kc - one with the regulator on the back of the alt. and one with the regulator attached to engine bay.
    the one currently on my 4k has brokeded and i got a bosch replacement but it is the wrong type..i need the external regulated one.
    if anyone here has any sitting around or for sale please reply here or PM me.
    i am willing to swap for the bosch one.
    also...would it just be simpler to swap the type of alternator? im not very good at wiring and stuff so how easy would it be?
    thanks in advance
    sven
    AE71 Build Thread
    Nathan
    Lilydale
    The bosch unit is FAR better, and it is easy to wire up!
    simply put the thick charge wire on the bolt as normal, then run one wire from the male blade terminal on the back of the alternator to the yellow wire in the plug that used to go into the external regulator.
    if wired correctly, the charge light will illuminate when ignition is turned on.
    and thats how you upgrade!
    hope this helps mate
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    If you still need one, I got one from a 4ac sittin around, you can have.
    PM if you want it.
    Svenbot
    East
    thanks guys... will try later
    is it as simple as what sprinter86 said?
    never had to replace one of these so im pretty clueless
    AE71 Build Thread
    Kieran
    why dont you ask in the technical section?
    Svenbot
    East
    thought id need a replacement alternator in sa
    had it tested and its still sparking etc.
    so im getting the brushes replaces and the whole thing cleaned.
    AE71 Build Thread
    Kieran
    cant you return the replacement from where you got it?
    Svenbot
    East
    might do that
    got the whole alternator cleaned up. put it in today and she's running fine now.
    was way easier to do that than switch all the wiring etc.
    thanks for your help guys
    mods can delete
    AE71 Build Thread
  1. alternator
    By d1staz in forum Cars or Parts Wanted
    Last Post: 11th June 2012, 05:56 AM
  2. help with alternator???
    By Tim.duncan in forum Technical - Questions
    Last Post: 21st March 2010, 09:42 PM
  3. Alternator?
    By Ksevn-T in forum Technical - Questions
    Last Post: 20th March 2009, 10:40 AM
  4. alternator
    By Buddy in forum Technical - Questions
    Last Post: 24th November 2006, 01:12 AM
  5. alternator
    By aeke7086 in forum Technical - Questions
    Last Post: 22nd September 2006, 10:24 PM
