Results 1 to 10 of 16
Thread: Cant use Ae101 4agze flywheel?
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Default Cant use Ae101 4agze flywheel?
    Hey guys, noob question sorry but i cannot use the standard flywheel for my ae101 4agze can i??
    Was planning to just get a clutch to suit, but apparently different splines to a T50.
    From the exedy book the standard flywheel measures 230mm
    If so should i just go a standard 16v 200 or a 20v 212mm?
    Veteran driftke70's Avatar
    Ryan
    Buderim
    yeah standard 16v, 20v if your keen
    wheelfriends.wordpress.com
    Grant
    Gold Coast
    Cool man cheers
    c
    212mm would be alot better to use.
    i used 212mm on my old 86 and never had a problem,
    some people using 200 have had problems with the clutch slipping and frying after only a few months.
    you can make a ze fly work BUT its very ghetto, as you either have to space the bell back or let the flywheel run a groove in the bell housing
    Veteran johl's Avatar
    Johl
    i run a 200mm and had no slip. if i didnt buy a brand new lightened fly wheel and clutch i prob would have gone 212mm just for some re assurance
    Oldschool Member
    Mar 2005
    Roy
    Bris
    I've had nothing but troubles with clutches and my 200mm set-up.
    Will definately be going 212mm.
    Qucik question.
    All 4a's are 8 bolt fly's yeah? Just wanna know definately which motor to pull a 212mm off.
    Jonathan
    #A-FE is 6 bolt crank
    4A-GE is 8 bolt crank
    212mm flywheel is off smallport 16v, and 20v. Blacktop is lighter.
    The GZE flywheel and clutch jams on a T50 bellhousing, but I know of people using it, and just let it hit and grind it's way to clearance.
    Nathan
    Lilydale
    just to add to that, ive heard the 225mm GZE clutch/flywheel fits into most adaptor bellhousings for w series gearbox, which means all you need to do is buy a rt142 clutch disc(225mm in size, spline to suit w series)
    Thats my plan anyway!
    Grant
    Gold Coast
    Righto, think i might source out a 212mm flywheel... depending on the cost
    Ive been running 200mm flywheel for two years and its really only started slipping when it got really bad lol
    Hugh
    I just bought a 212mm flywheel off RollaClub for $30...not an expensive upgrade at all
  1. 4AGE AE101/AE111 Toda Lightweight Flywheel
    By itrungs in forum Car Parts For Sale
    Last Post: 23rd December 2012, 11:12 PM
  2. 4agze Accel cable mount, 4agze ae101 air intake temp sensor
    By Roo. in forum Cars or Parts Wanted
    Last Post: 13th May 2009, 07:00 PM
  3. ae101 4agze loom/ecu onto ae92 4agze?
    By 84ae86coupe in forum Technical - Questions
    Last Post: 16th May 2008, 01:30 PM
  4. WTB: [BNE] 212mm 8-bolt flywheel off a 20V AE101
    By PuGZoR in forum Cars or Parts Wanted
    Last Post: 12th June 2007, 09:30 PM
  5. AE101 4AGZE Flywheel + AE101 215mm 6-bolt Flywheel
    By PuGZoR in forum Car Parts For Sale
    Last Post: 29th May 2007, 08:51 AM
