Page 10 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 91 to 100 of 101
Thread: 20V quads on 16V head
  1. #91
    so many ppl think duration creates more power.....durations put simply moves the "powerband"....bigger numbers arent always better......
    learn to drive ur car within a bee's dick of its potential before u bother building a engine that ull prolly only ever drive to 70% of its capabilities
  2. #92
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    i understand that i will be limiting its power, head is being built by a head shop, all shims are being taken care of by them, i just bought all the parts and did the porting myself, its gonna be a dedicated track car and towed to all events, and when the bottom end gives way, then i will build a fkn tough bottom end, i know that the powerband will be very high in the rev range, but until i have a tough bottom end, i wont be using 100% of the power
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
  3. #93
    Jul 2009
    Kane
    Coburg
    hmm sounds like a waste untill you build your bottom end.
    at least get your stock bottom end balanced.
  4. #94
    Richard
    South Oakleigh
    yeah that was planned, cant afford a mad bottom end atm as i still need to set up a good driveline n suspension package
    SQ ENGINEERING
    NCCE
  5. #95
    Jul 2009
    well it would suck then if that weak bottom end of your decided to let go at constant 8000rpm age and throw a piston or two into that head that you just spent all your money on...
    i have a 7 rib bottom end sitting in my shed if your interested.. it would be great with a simple ring and bearings.. and good balance.. it would see 8500rpm all day no troubles.. balance is the key..
  6. #96
    Veteran driftism's Avatar
    Andrew
    Watsoia
    has anyone used a 16v tps on the 20v quads? i tried fitting one to mine the other day and it bolted up fine, the only problem i can see is that it may not rotate the same way as the normal throttle body, and it's slightly larger than the 20v one.
    saves re-wiring the tps plug if it does work though
  7. #97
    Stefan
    Parkinson
    so it can run with the stock ecu ok?
    how streetable would it be on jdm bigport ecu?
  8. #98
    Andrew
    Watsoia
    runs pretty good, but i am getting LS2 spec fuel economy, (100km to 25 dollars worth)
  9. #99
    Stefan
    Parkinson
    <div class='quotetop'>QUOTE (4AGE - 86 @ Feb 24 2008, 12:59 AM) </div>
    ouch
    chews through fuel
    but with microtech it can be tuned safer and more efficient?
  10. #100
    Andrew
    Watsoia
    yeah will be heaps better with a microtech
  1. Jdm t50, Built 16v head, Quads + more
    By trueno_coupe in forum Car Parts For Sale
    Last Post: 30th October 2011, 01:27 PM
  2. Replies: 0
    Last Post: 19th May 2011, 09:40 PM
  3. Replies: 7
    Last Post: 2nd September 2010, 04:17 AM
  4. 20v quads on 16v 4AGE head
    By PHAT86 in forum Technical - Questions
    Last Post: 9th July 2008, 05:45 PM
