Page 6 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 51 to 60 of 101
Thread: 20V quads on 16V head
  1. #51
    Jul 2009
    timing is where it's at with tuning NA.. thats why i didn't even see SAFC as a viable option..
  2. #52
    Ok
    Seamus
    Milton
    No, you were saying that it wasn't possible/streetable to run quads without an SAFC, which is clearly wrong.
    You just can't get the most power out of a sprinter (as you said) without being able to touch timing.
    I just wanted to clear up that it IS possible to do so, on a budget. Again, if you are after the best gains, aftermarket management is the key.
    ^ Clicky clicky!
  3. #53
    isnt timing different to ecu? like mechanical
    i'll be sure to check it out toxin , and how bout ur budget street racer matty, any links to it?
  4. #54
    Veteran Robo86's Avatar
    Rob
    yeah our plan is just to do SAFC with the ae101 quads, i know i wont get as much power as i could with aftermarket management, but it should be a great start. ill save some money for a power fc or something and throw one of them in down the track.
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  5. #55
    Jul 2009
    WOT shouldn't need to be touched... just idle/cruise maps..
    leave the idle a bit fat.. cos you can't run a cold start injector..
    Toko - i didn't delve too far into the SAFC... basically i just went for the complete solution first time, as the $$ wasn't really an issue..
    retail on an adaptronic fitted and tuned drive in drive out from Ant at Kaizen is $1500... retail... that is..
  6. #56
    Veteran driftke70's Avatar
    Ryan
    Buderim
    my quads are going onto a jdm bigport in the coming weeks, i was thinking of going adaptronic or razor back ecu's, any opinions other either or others and keep into account viability money etc.
    oh also what adaptors are best/easiest/cheapest.
    wheelfriends.wordpress.com
  7. #57
    Oldschool Member
    Mar 2006
    anyone have a link for somewhere to buy the adaptor plate for silver top quads to a bigport 4AGE????? post it up pleasse
  8. #58
    ajps sells em
  9. #59
    Ok
    Seamus
    Milton
    T3 also sells them. (Techno toy tuning), which is where ajps get them from.
    Only other place (that i've seen) is a few groups on yahoo jp, but they aren't cheap either.
    I'll be making one soon, will see how that goes, otherwise i think there's no option but get the T3/AJPS one
    ^ Clicky clicky!
  10. #60
    Sep 2009
    I'm about to put quads on my redtop in an Austin Healey Sprite. ST quads on a T3 manifold. Also putting in some HKS 272 8.1 cams and doing some mild porting – mainly cleaning up. Already running a Motec M4. Clearance issues mean I might have to chop the TPS mount off the end TB and stick an aftermarket TPS on the other end of the quads. Not sure about trumpets/filters/airbox yet (clearance again). I'd like to get a cold air intake system – the engine bay is pretty tight and gets pretty hot.
    If, on the off chance, anyone is running similar with a Motec...I'd love to get hold of a motec map to suit that I can use as a headstart on the tuning.
    I'll put details up of how it goes once it's in.
  1. Jdm t50, Built 16v head, Quads + more
    By trueno_coupe in forum Car Parts For Sale
    Last Post: 30th October 2011, 01:27 PM
  2. Replies: 0
    Last Post: 19th May 2011, 09:40 PM
  3. Replies: 7
    Last Post: 2nd September 2010, 04:17 AM
  4. 20v quads on 16v 4AGE head
    By PHAT86 in forum Technical - Questions
    Last Post: 9th July 2008, 05:45 PM
