Results 1 to 10 of 10
Thread: 86 cambertops in a 70
    Default 86 cambertops in a 70
    Hey guys,
    I know this has probably been asked 100 times but i cant seem to find a thread on it at the moment. Can i use 86 cambertops in a ke70 im pretty sure the stud patterns the same but is the hole in the middle the right size for the adjusters to do their job??
    Cheers, Greene
    Senior Member ke70 xx's Avatar
    Troy
    Woody
    Yes they work.
    Quote Originally Posted by MINIHORSE View Post
    "if i ever get another 86 i think it will be a track only car"
    Tried that....failed.....you will too....its like sleeping next to a supermodel everynight and only getting to nail her 5 times a year
    Veteran Konakid's Avatar
    Henry
    Eastern
    yes......
    sweet as.. thanks
    Senior Member Ksevn-T's Avatar
    Do you have to put a spacer inbetween the camber top and the spring hats?
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    When running 86 tops in a 70 it reduces your caster considerably..
    No easy way to fix it other than getting a new top plate machined that places the top of the strut back in the right location...
    West
    Or do what i did and wait until you can find some added caster tops for ae86.
    They will be within 2 mm of perfect for a ke70 or ae71.
    Cusco make them, I think mine are Teins. Cheers for the tops, Seamus.
    alright cheers for that guys.. ill look into it, with the increased caster tops can you adjust the castor back that 2mm you mentioned??
    Henry
    Eastern
    No, but there is plenty of adjusment in the stock castor rods.
    Alrite cheers thats what i was meaning..
  1. Replies: 7
    Last Post: 15th August 2011, 02:44 AM
  2. 86 Cambertops
    By DAMO46 in forum Cars or Parts Wanted
    Last Post: 18th December 2009, 12:57 PM
  3. 86-70 struts
    By 70fun in forum General Topics (No Technical Questions)
    Last Post: 25th April 2009, 09:01 PM
  4. 70 71 86
    By madi86 in forum Cars or Parts Wanted
    Last Post: 9th January 2009, 06:29 PM
  5. 86 Rear Coilovers in a 70?
    By 20sil in forum Technical - Questions
    Last Post: 12th February 2007, 02:20 PM
