Results 1 to 10 of 19
Thread: strut choice for my ke70
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    Default strut choice for my ke70
    just asking is there any differences in using an ae86 strut or an xt130 strut in my ke70 e.g bolt straight in and better
    thanks,
    mereki
    ~KEEP DRIFTING FUN~
    Veteran shift_rook's Avatar
    SE Burbs
    an xt130 has a twin piston caliper so you won't really have to do any further brake upgrades, much better IMO, someone please correct me if i'm wrong or they just disagree
    Mereki
    Badassville
    will it bolt straight in tho or wat else will i need
    ~KEEP DRIFTING FUN~
    Senior Member resol's Avatar
    steve
    vic
    xt130 bolts straight in 100% garranteed, only thing that you must change, is to keep and use your ke70 springs, and strut tops (that bit ontop of the spring which bolts into the strut tower).
    advantages: bigger twin piston brakes, larger shock tube which means aftermarket replacements are availiable (same as ra60/ma61/ae86 etc shocks ).
    only downside, is the steering arms are ~10mm longer off the top of my head maybe 5mm? which means you do loose a little bit of lock. also the king pin angle (angle of the stub axle to the strut) is bigger meaning you get a slight change in camber (with stock ke70 LCA it may be +.5 degrees camber)
    my advice, xt130 struts, and xt130 LCAs, with a lock spacer.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    性交を愛する
    Agreed with resol and you can always cut and shut the steering arms to make up for the lack of lock with unmodified ones.
    marvis.
    Senior Member KE70's Avatar
    Alek
    Lalor
    or use AE86 arms?
    Veteran slydar's Avatar
    Dimitri
    yeah xt are 100% compatible with ae86 steering arms. its what i have im my car.
    Mereki
    Badassville
    um just wondering how much should i pay for a pair
    ~KEEP DRIFTING FUN~
    Veteran Konakid's Avatar
    Henry
    Eastern
    just use 86 struts, far lighter, still 2 inch for good shock options, ps arms will give awesome lock, FC brakes are easy and as big as you'll ever need, retain factory geometry.
    SE Burbs
    but then you have to fork over for fc brakes which cost an absolute load, just the bare basics will cost about $800 where you can pull rona struts from the wreckers for bout $100 for thr pair with everything you need then spend $150 on ps arms and for $250 you get something that's sweet
  1. ke70/ae86 camber tops and ke70 strut brace
    By sld sho in forum Cars or Parts Wanted
    Last Post: 18th October 2011, 01:44 PM
  2. ke70 strut brace s.a
    By wagoooon in forum Car Parts For Sale
    Last Post: 16th October 2011, 08:07 PM
  3. ke70 tyre choice
    By scott_22 in forum Technical - Questions
    Last Post: 29th July 2009, 03:41 PM
  4. Eds ca18det ke70 - the worst choice
    By worked in forum KE70 / AE71 Owners Forums
    Last Post: 19th July 2009, 11:00 PM
  5. strut choice for big brakes
    By sundee in forum Technical - Questions
    Last Post: 8th June 2009, 02:24 PM
