Results 1 to 10 of 11
Thread: Taking apart 3 piece rims.
    性交を愛する
    Default Taking apart 3 piece rims.
    What do people use to reseal the rim?
    Can I just tighten the nuts when a allen key/spanner or will I need a torque wrench etc?
    Any more info I should know?
    Thanks,
    marvis.
    Jonathan
    You can use silicon.
    Oversized 86
    i used blue selastic...you know that blue gasket making junk...
    just run a line on the inside edge before you bolt it together...(same as with a diff)...or you can just run a thick bead around the join on the inside of the rim (where the tire will fit over)
    works fine
    Senior Member Whip's Avatar
    Jordan
    Torque wrench is needed i believe
    Veteran Robo86's Avatar
    Rob
    yer id torque it and run a sealant
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    性交を愛する
    Fuck.
    Where can I get a wrench from to do the job and cheap?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    total tools? do they even have that in brissy?
    FTP.
    性交を愛する
    Northgate.
    What about repco or something?
    marvis.
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    no need for torque wrench
    but im dodgey to some.... i have dine this before... just do them up "FT" (fucking tight)
    u will be right
    MY JZX83 (clicky)
    性交を愛する
    That's what I was thinking. I'll see how it goes and let you guys know.
  1. 13 Rims 3 piece
    By MiniMafia in forum Car Parts For Sale
    Last Post: 9th March 2010, 09:19 PM
  2. Trade or Sale: [BNE] Simmons 2 piece rims
    By PuGZoR in forum Car Parts For Sale
    Last Post: 23rd August 2007, 08:13 PM
  3. Safety of welded 3 piece rims
    By starni_boy in forum Technical - Questions
    Last Post: 4th April 2006, 12:17 PM
