Results 1 to 10 of 10
Thread: Good diff shop
    Senior Member stylz's Avatar
    Art
    Melb
    Default Good diff shop
    heya guys, just having some odd problems with my rear end (kaaz 2way) and i cant seem to figure it out
    im thinking its the crown and pinion gear as im getting some pretty harsh sounds, vibrations from the rear end when ever i turn slightly.
    going in a straight line its all fine, but as soon as i have to turn a corner and a gear is engaged it just shudders and makes awefull sounds.
    ive taken the axles out, and they are perfect, taken the diff out and taken it apart and its all fine as well. no damaged teeth on either of them or the crown and pinion :/
    its been happening last saturday, replaced the rear end bushes with some peders stuff as they ones on the car were flogged out hard. and i had a decent session saturday night, and since then its just been getting worse and worse and i cant track it down :/
    so anyone know any decent differential places that are located in the south east preferably?
    thanks guys, much appreciated -arthur *sorry for long post* :p
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    as far as im aware from basic posts from previous forums if its getting noisy just telling you for an oil change ? that is if its lsd problem, but anyway, theres a guy in sunshine dont know address exactly but he knows ae86's very brief and he can source stuff if u need it and he can do w.e u want / need for diff
    Senior Member rallystanza's Avatar
    Jeremy
    Vic
    Straya
    If its a KAAZ mechanical LSD the noises you are getting are normal.
    If you want it to get better, do a couple more sessions of the running in fiure 8's, make sure you do them as described. Change the oil with something decent. Its all part of having a diff like that. My KAAZ did it for ages and I ran it in 4 times. It was normally pretty good after that.
    You can also get Limslip diff additives which are added to the oil and reduce shuddering between the clutch packs.
    If all else fails, then a mechanical jap LSD is not for you, haha!
    Art
    Melb
    The problem is that ive been driving around with it for a year. Its beem relativly quiet until recently.
    I have a kaaz in mine and my bro has his welded, so i know what a locker feels like. But this feels like the rear end is grinding.
    This all started on sat and yes ive replaced my diff oil as well
    Senior Member Ksevn-T's Avatar
    Jack macknamara Diff's (Not sure on spelling)
    In Moorabbin. The guy is Magic with diffs. Arrogant F**k though.
    Alex
    Dave
    Western Suburbs
    rallystanza is spot on, try putting some lsd additive inthere, it quiets down lsds as the clutchpacks get noisy after abuse
    Senior Member JDM_KING's Avatar
    jake
    West Side
    does having a 2 way lsd put strain on the gear box?
    Art
    Melb
    awesome mate, you da besttt
    VLNY
    Senior Member shakes's Avatar
    Simon
    Vic
    Melb
    Quote Originally Posted by Ksevn-T View Post
    Alex
    very true on both counts
  1. Who is good engine rebuild shop in Bris or Gold Coast
    By Fooly Cooly in forum Brisbane & QLD Events and Discussion
    Last Post: 27th March 2012, 09:00 AM
  2. Good alignment shop willing to work on very low car near cbd?
    By keiichi in forum Sydney & NSW Events and Discussion
    Last Post: 7th July 2010, 09:24 PM
