Results 1 to 8 of 8
Thread: Adjustable pan hard rod question
    Senior Member vivioman's Avatar
    Vernon
    Ellenbrook
    Default Adjustable pan hard rod question
    Hi guys,
    I'm bringing my car to my mech to install lowered springs and shocks.
    I also have an AJPS adjustable pan hard rod which I will need to get installed.
    My question is:
    1) Do I get the mechanic to install the pan hard rod when he installs the springs and shocks or
    2) Do I get the suspension place to install and adjust it when I bring the car in for alignment?
    If the mechanic installs the pan hard rod and does not make any adjustments to it, will it have an adverse effect on the suspension?
    Thanks
    Veteran slydar's Avatar
    Dimitri
    get the mech to put it in, will be cheaper, he can adjust it too. just measure equal gap tire to guard, thats all there is to it.
    dan
    adelaide
    adelaide
    its quite easy to do your sels, an ae86 is a easy car to work on
  • #4
    Senior Member Moebius's Avatar
    Christian
    Is that all there is to adjusting the panhard rod? Make sure there is equal gap between tyre and guard on both sides? So it should be done with the car on the ground?
  • #5
    Senior Member adam's Avatar
    Adam
    Yes. On level ground if possible.
  • #6
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Save yourself some money and do it all yourself. Spanners and a ratchet set, jack, axle stands. Away you go.
    Front you will probably have to get your mechanic to do it, don't want the spring hats flying off and killing you.
    This is for the rear.
    -Top Shock Nuts off
    -Undo shock bottom mount bolt
    -Compress shock with your hands and manouver it out
    -Jack it up a bit more and the springs will pretty much fall out.
    Do the same but in reverse order.
    While you have it jacked up,
    -Undo the panhard rod mounts/bolts
    -Adjust the adjustable one to roughly the same length as the original
    -Install the same way you pulled it out
    -Do some fine adjustments with the car on the ground.
    Voila!
  • #7
    Vernon
    Ellenbrook
    Thanks guys, how do you adjust the gap so that they are equal on the level ground?
    Do you mean crawl under the car on level ground and adjust the pan hard rod to get the equal gap or jack the back of the car up, do a rough adjust the put it on level ground to test again?
    sorry noob question.
  • #8
    Oldschool Member
    Mar 2005
    Roy
    Bris
    After it's in and everything else is done. Put it on the ground, check gaps on either guard. Then squeeze under the fuel tank and adjust it, jack it up so the wheels are off the ground and then let it down, this will show you how much you've adjusted it. And just continue doing that untill you get it where you want. You can do it without having to jack it up and down. I just figured it's slighlty more accurate as you're not flexing sidewalls etc..
  • Similar Threads
    1. Quick question: adjustable pan hard rod
      By Bozu in forum Technical - Questions
      Last Post: 16th June 2011, 05:00 PM
    2. My experiences from modding my pan-hard
      By Sam-Q in forum Technical - Questions
      Last Post: 7th May 2011, 10:05 AM
    3. trd 2way & whitle line pan hard bar
      By andy86 in forum Car Parts For Sale
      Last Post: 10th October 2009, 10:51 AM
    4. Pan-hard rod strength+bush theory
      By Sam_Q in forum Technical - Questions
      Last Post: 19th May 2007, 03:52 PM
