Results 1 to 8 of 8
Thread: Advantages of smallport mani on bigport.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Default Advantages of smallport mani on bigport.
    Was wondering if anyone here has tried running the small port mani on a bigport engine and wheather they had any decent results...
    Small port mani is much cleaner design and aparently flows better...
    Wish I had gotten a small port to start with
    Also anyone had good gains from running 20v quads.??
    I'd like to do that eventually but need more cash..
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    it wont do anything unless you run an aftermarket computer
    FTP.
    Jason
    Nundah
    The question wasn't is it possable...
    It was "what are the gains" from doing this..
    And I have an after market ecu...
  • #4
    Oversized 86
    the reasoning behind it is due to the larger CFM of a smallport manifold...it takes alot of work to get it done...
    there was a guy in the us that did a whole write up on it...
    jump on google and i reckon you would find it without to many problems
  • #5
    Veteran shift_rook's Avatar
    SE Burbs
    with 20v quads you'll gain much better response, possibly get a couple of extra hp too
  • #6
    Jason
    Nundah
    Yeah I already looked.. thats why I asked...
    Couldn't find squat....
    For some reason I found a lot of links selling adapter plates to put a bigport mani onto small port...???
  • #7
    SE Burbs
    so you can then run a fatory rwd bigport manifold instead of having the worse looking cut and shut manifold
  • #8
    Oversized 86
    the adapters are bigport mani onto a smallport because there is NO rwd smallport...
    so the adapters were made to make converting smallport easier
  • Similar Threads
    1. [VIC] Bigport 4AGE Block, Intake mani and spark plug leads
      By 4ABHGE in forum Car Parts For Sale
      Last Post: 22nd June 2012, 01:51 PM
    2. Replies: 12
      Last Post: 15th January 2011, 07:15 PM
    3. Replies: 5
      Last Post: 23rd February 2010, 06:48 PM
    4. WTD smallport RWD intake mani
      By n00bvak in forum Cars or Parts Wanted
      Last Post: 6th July 2008, 06:13 PM
    5. Advantages and disadvantages of a locked differential...
      By PuGZoR in forum Technical - Questions
      Last Post: 2nd November 2006, 01:45 PM
