where do u get the sandwich plate from???
the plate doesn't block any passages off.. it's a bog stock factory plate that come out on most 4AGE/4AFE's in the ae82/92 rolla range..
bought off the wreckers... ha! can't remember the last time i did that! more like 'wow did you see that just fly over the fence??'
Cass - i knew you would say that.. that is now fixed.. the drama was a weaping sandwhich plate oring.. all good now though!! thats why it's still clean down there!
FWD 4age/4afe ae82/ae92 rolla.. most of them run factory oil coolers.. all this stuff is toyota genuine..
can find them on celicas and ae95's too
ok thanks people pick and payless here i come
the what??? stock GZE cooler? dunno what your looking at... but a stock GZE intercooler is air to air... this is an oil cooler..
although they are small and quite effective.. it is winter, but it seems to be effective in the fact that the temperature stays more stable.. doesn't creep up after heaps of fanging at low speed and or stop start etc.. like skid pan stuff.. or drift days where there may not be alot of air going straight through the radiator...
also i haven't seen a factory GZE with one of these plates and an oil cooler on it..
upgarage - yep.. i have an AE94 hatch that i gave to my dad.. 4AFE with one of these coolers.. it seems to be the cars that came with air con, maybe due to the condensor? and or the climate in australia where the cars were designed for.. not many jap halfcuts i have seen use them if any..
LOl @ matty
No man, i meant the stock gze oil cooler sandwitchplate thingy. Had a look at mine, and yes its just a sandwhich plate. Needs holes drilled and fittings connected to make it all work. OH and a HOLE in the sump
And yair, ive seen the lil coolers on 4afe's aswell. Strange i know but meh.
ha ha i thought i might have read that wrong.. what sandwhich plate are you talking about?!
is yours similar to a 20V one? where it's pretty much a spacer???
