Results 1 to 10 of 13
Thread: a simple question
    Default a simple question
    from a simple minded person...
    will an ae86 strut brace fit in my ae71 ?
    and also would this be any good to me or is there to many differences:
    http://store.autosportsupplies.com/m...gory_Code=SPPB
    cheers, doof
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Strut brace would fit....
    The width between the strut tops are different...
    And as far as Im aware all the bushes in that kit you'll be able to use....
    Just did my KE and I think from memory the only difference is the rear sway bar D bushes are different.. But they have a different diff to an 86
    what do you mean the gap between the strut tops are different?does this mean i'll have to mod them a bit ?
    cheers for the reply
    Jason
    Nundah
    If you bolt the brackets for you strut brace on then the bar that runs between them won't reach... thinks that a KE/ae71 bay is about 30mm wider...
    I thought they would be the same as well..
    But went to put my mates spare brace on and it don't fit...
    bummer oh well it was worth an ask, know any places that make ae71 braces?
    Jason
    Nundah
    AJPS.. maybe.???
    Scammer, DO NOT BUY FROM ME!
    buy an adjustable one, i had one on my ke70 and it fitted
    Mt Macedon
    ADM AE86 and E7 run different strut tops. The inside of the three studs holding it in place is about 5mm out between them. So the ends of an AE86 brace may not suit the E7 studs. Easy to redrill though.
    Also I've heard it rumoured that JDM AE86 strut tops are the same as E7, so maybe a jap strut brace will fit.
    wow what a pain in the arse ay ??
    does it really stiffen your car up that much any ways?
    性交を愛する
    Quote Originally Posted by Hen may possibly be a nut View Post
    Ummm. That does not make any seance. The strut tops will still be in the same position.
    Adjustable is the go.
    marvis.
  1. Less is better, yet simple but effective
    By AE71 Rolla in forum Offtopic Discussions
    Last Post: 18th September 2008, 03:53 PM
  2. Two relatively simple questions
    By KameSama in forum Technical - Questions
    Last Post: 8th May 2008, 06:10 PM
  3. simple question
    By sleek_ae71 in forum General Topics (No Technical Questions)
    Last Post: 5th July 2007, 12:38 AM
  4. simple question for most thermostat
    By shaun2 in forum Technical - Questions
    Last Post: 8th June 2007, 10:28 PM
  5. Simple Conversion Hook-Up
    By yuri in forum Technical - Questions
    Last Post: 13th April 2007, 08:00 PM
