Results 1 to 3 of 3
Thread: alternator bracket
    Default alternator bracket
    hi all, just a quick one
    does anyone know if the alternator brackets are the same for a 4age and
    4agze?
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Only problem with a gze bracket is that a gze alternator is mounted on the exhaust side of the block, obviously cause there is a supercharger in the way of the original spot which you find on n/a 4a's. I don't think they would be interchangeable as from what I would think they'd be reversed 180 degrees from eachother.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    GZE alternators don't fit into GE brackets either.
  • Similar Threads
    1. 4agze alternator bracket
      By dehney in forum Technical - Questions
      Last Post: 5th November 2011, 09:55 AM
    2. Alternator bracket!!
      By Rice86 in forum Technical - Questions
      Last Post: 3rd May 2009, 08:38 PM
    3. Alternator bracket
      By Insane in forum Cars or Parts Wanted
      Last Post: 15th May 2008, 08:49 PM
    4. RWD alternator bracket
      By JDM-086 in forum Technical - Questions
      Last Post: 9th November 2007, 08:44 PM
