Results 1 to 10 of 12
Thread: N/A build up
    Oct 2005
    heys guys im getting a new motor for my 86. its a jdm 96kw bigport and i want to build it up to be an n/a monster! just wondering what advice you could give me on parts to install and things like that
    tim
    Mar 2005
    some good advice would be search these forums, read billzilla's website and phil bradshaws among others.......
    Oct 2005
    thanks mate
    Thurston
    Vic
    North East
    If you want to pour money into a 'monster n/a setup' then it would probably be a better investment to start with a stronger more powerful platform. Like a 100kW 'redtop' 4age.
    Oldschool Member
    Jun 2006
    what wrong with the JDM 96kw? its got the same bottom end. and the difference is only 4kw??
    Nat
    Newcastle
    The bottom end is different, the rods and crank is a bit stronger in the 100kw.
    Also the head on the smallport (100kw engine) lends itself more to producing torque lower in the rev range, whereas the big port (your motor) has a head that works better higher in the rev range.
    I'm using a big port myself, mainly because I got the motor very cheaply. Either motor is a massive improvement over a 4ac anyway!!
    Jul 2009
    JDM engine is exactly the same as the ADM AE82 motor... just ecu/ accesories are different..
    18mm gudgeon pins, and 40mm big ends/ 3 rib block
    the 100kw/20v/GZE has
    20mm gudgeon pins, 42mm big ands, and 7 ribs on the inlet side.. as an added bonus they usually have smallport heads.. (small port is easier to get power out of for street/race use, a big port head would require a bit more work)
    Terry
    Ipswich
    the 86kw bottom end is perfectly OK if properly prepared. if you expect to get much over 140kw, then the larger crank & rods found in all 100kw and 20V's is a good idea, but the ZE rods are too heavy so avoid them. The secret is in the detail. we build race & street versions of these engines regularly
    see . contact me direct if interested, not via this forum.
    Elite rthy's Avatar
    Leo
    Tulla
    how much power do you want and whats your budget?
    Jul 2009
    should be whats your budget = how much power you'll get lol going all out NA can become quite expensive
  1. Here we go again, build no. 2
    By starni_boy in forum AE86 Owners Forums
    Last Post: 1st January 2013, 03:00 PM
  2. The Build
    By Damien in forum KE70 / AE71 Owners Forums
    Last Post: 3rd July 2011, 08:26 PM
  3. is there a build thread on this??....
    By corey70 in forum General Topics (No Technical Questions)
    Last Post: 25th September 2009, 07:45 PM
  4. N/A build
    By aussyboyz in forum Technical - Questions
    Last Post: 8th May 2009, 12:26 PM
