Results 1 to 9 of 9
Thread: gearboxes and suspenion setup
    Default gearboxes and suspenion setup
    theres so many gearboxes and suspenion setup out there!!
    i was just wondering what gearboxes some of you use, for what purpose and what you think works the best? also what is the strongest and reliable gearbox that can handle abit of a thrashing?
    alsoo whats some good suspension setups?? seeming that i dont know anything about suspension !
    Jonathan
    Mate, you have drunk more wine than me.
    Veteran bigm's Avatar
    Gold Coast
    R154 Gearbox would be your best bet, good for any type of driving, unbreakable
    And a good set of kingspring Super lows and monroe GT shocks should do the trick
    lol
    Veteran shift_rook's Avatar
    SE Burbs
    for shocks for the mainstream just get like trd shocks with maybe an ajps, ocs spring. for box if you're just going to drive it normally and it's a stock 4age or less a t50 would be fine
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    polenesia for lyfe!
    FTP.
    when buying springs what do all the ratings mean..like From 3.2kg/mm – 10kg/mm..and everything else?
    just so i know what i need and dont..can anyone explain thanks
    Jonathan
    3.2 is soft. 10 is hard.
    RESEARCH...dnt rely on ppl to spoon feed you
    Veteran johl's Avatar
    Johl
    Quote Originally Posted by fijian_flanker123 View Post
    when buying springs what do all the ratings mean..like From 3.2kg/mm 10kg/mm..and everything else?
    it represents how many kg the spring can hold per milimetre. thats why some of the springs are really long, so they can support a lot of weight. depending on the weight of ur car and urself u may need longer springs and some times they get too long for the strut so u will need longer struts.
    it may get to a point where the conventional strut is too long to be useful as you are carrying alot of weight. at this point you will have to consider changing to a coilover or even a leaf spring front, as this may get the desired ride height.
    dont forget when totalling ur weight to divide by 4 as there is 4 springs. if u have adjustable shocks you will also have to divide the total weight depending on what number yout shocks are on.
    ie. your car and urself weigh 990kg, divide by 4 because of the 4 springs. this totals 247.5. and with the adjustable shocks set on 28, this will give you a spring rate required to be 8.8392857142857142857. so the springs you want for the front will be approx 8.8kg per mm.
    i cant exactly remember how to work out the rear as it has something to do with the pinion angle and tdc of the exhaust cam. maybe someone else can help in this regard.
  1. centreline rims and t18 suspenion
    By kronix in forum Car Parts For Sale
    Last Post: 19th February 2012, 06:50 PM
  2. Ke70 front suspenion UPGRADE
    By trikzlane in forum Car Parts For Sale
    Last Post: 26th May 2010, 08:07 AM
  3. KE70 Front Suspenion, Brakes and 4AGE Leads (VIC)
    By Bluterus in forum Car Parts For Sale
    Last Post: 17th May 2010, 11:17 AM
  4. ae86 suspenion / diff / lsd / body bits etc
    By Evan in forum Car Parts For Sale
    Last Post: 27th May 2009, 02:00 PM
  5. Bent chassis rail - Implications for drift suspenion setup
    By Golberg in forum Technical - Questions
    Last Post: 20th May 2009, 11:27 PM
