Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Other Throttle Bodies
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Default Other Throttle Bodies
    Hey guys,
    I did a search but couldn't find anything, I think the stuff I am thinking off is possibly on the old forum.
    I'm wanting to know if there are any larger throttle bodies that can be bolted on with minimal mods. Obviously I will need to run the same TPS for everything to work.
    If anyone knows of any that are direct fit for a JDM bigport 4AGE.
    Cheers.
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    i think EFI hardware make a setup for the 4age maybe give them a call
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    a land cruiser one? i remember reading something about that on the old forums
    FTP.
    Akio
    Mt Haruna
    Japan
    a 3SGE will be minimal mods 65mm? size
    a xf falcon throttle body (requires map sensor) 75mm size
    a landcruiser will work little bit of pfaffing about with it though 70mm size
    a V6 camry one cant remember if it just bolts up though 65mm size
    a 3rz one will work at 70mm? size
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    gtir?
    gay
    n1gger land
    n1gger land
    south korea seoul
    i used a v6 camry throttle body on my smallport. its a 3inch one, same as sr20 size.
    barely clears the trueno bonet tho !!
    gay
    n1gger land
    n1gger land
    south korea seoul
    Quote Originally Posted by AJPS View Post
    Gtr........
    Quote Originally Posted by 350hp4agte View Post
    gtir?
    i think lawson was talking about using 4 of 6 gt-r throttle boddies on a 4age as quads.. it has been done before.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Why would you want to change it..??
    Unless you have a crazy engine there is apparently almost no gain to be had from running a bigger throttle body...
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Quote Originally Posted by --Redwork-- View Post
    your wright there is no gain al all of running a bigger throttle on a 4age but 4agte or 4agze maby but even then why bother with a bigger throttle body upgrade something else for a little more go
    the dyno pull to 300rwkw
    Oldschool Member
    Mar 2005
    Roy
    Bris
    So you've guys have done it and tested flow rates? I doubt there would be zero gain.
    The next step for me is a rebuild, so I don't know really why I would rather spend 2-3k on a rebuilt or $50 on a slightly larger throttle.
  1. silvertop throttle bodies
    By spoon in forum Car Parts For Sale
    Last Post: 23rd July 2007, 11:20 AM
  2. quad throttle bodies
    By Cerby in forum Technical - Questions
    Last Post: 24th January 2007, 10:49 PM
  3. 4age throttle bodies
    By brad in forum Technical - Questions
    Last Post: 26th September 2006, 07:12 PM
  4. Throttle Bodies
    By 4AGE - 86 in forum Technical - Questions
    Last Post: 24th March 2006, 05:42 PM
  5. throttle bodies
    By Insane in forum General Topics (No Technical Questions)
    Last Post: 19th July 2005, 04:41 PM
