Page 13 of 42 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... LastLast
Results 121 to 130 of 415
Thread: S13 coilovers into AE86
  1. #121
    Mar 2005
    cool cheers champ...
  2. #122
    Scott
    Coombabah
    but do the mx83 rack ends go in easily or did they have to be re-tapped to fit, im assuming not? cheers
  3. #123
    Oldschool Member
    Mar 2006
    yep
  4. #124
    Mar 2005
    Is that sarcasm or a serious word of warning Professor for the peeps who wouldnt know?
  5. #125
    Mar 2005
    Ok after speaking with 86sp...... he used s13 LCA's and ended up with ridiculous camber (sus his members rides thread) So he had to have them shortened 30mm.......... whats the go....?
    Gilly you state that the S13 arms can be used and the camber is fine (judging from the pics of your car it looks that way) Im just puzzled why 86sp's car had such excesive camber........?
  6. #126
    did he have adjustable camber tops?
  7. #127
    Mar 2005
    yeh....
  8. #128
    Mar 2005
    Some pics of 86sp's setup........ (hope you dont mind champ)
  9. #129
    Jun 2009
    Michael
    Ahh, I have to state that this was with standard guards and camber tops still set at my original -1.5deg. If I pumped the camber all the way out to positive the tyres would have hit guards in a major way. I still think that it would have had a shit load of camber even with the plates at positive.
  10. #130
    Ferny Grove
    i was surprised at how much neg camber 86sp's front end gained using s13 arms. i actually used JZX81 arms but they are the same length from crush tube to balljoint as a s13 arm so all track and camber gains should measure the same.
    DRFT-86 check with some of the other guy's on here that have used s13 arms and see what they came up with.
    my pic on the front page is with cambertops set to max neg. at the moment my tops are set to a couple mm off centre (inboard) and i have -2.15* camber
  1. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
