Page 19 of 42 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... LastLast
Results 181 to 190 of 415
Thread: S13 coilovers into AE86
  1. #181
    Mar 2005
    its the difference of spending $300 or $80 that Im trying to figure out....
    I want clarity not maybe's.........
  2. #182
    Senior Member EVOSTi's Avatar
    Kevin
    Camden
    i dont know that adding spacers to your tie rods would help you with bump steer.
    yes you can use mx83 inners with s15 outers, ive seen it myself on sprinter saurus' car but if you dont wanna go that way there are other options as mentioned about 13 pages ago.
  3. #183
    Mar 2005
    thanks champ..... thats all I need to clarify...
    Im not sure how the spacers work... but they are nice HD tie rods so I will prob go that way with my conversion...
  4. #184
    Brad
    Central coast
    can you use ae86 strut tops with s13 coilovers, for the poor people that cannot afford camber tops yet?
  5. #185
    Kevin
    Camden
    you can, but its best you dont run a high spring rate, as this may punch through the rubber of your factory strut top.
  6. #186
    Brad
    Central coast
    i am running that risk at the moment with ae86 struts. is that what you mean?
    so they still fit with the s13 shocks?
  7. #187
    Senior Member rallystanza's Avatar
    Jeremy
    Vic
    Straya
    I is been running my factory slut tops for about 3 years now with tokiko HTS and 8KG spring rate and have shown the car no mercy whatsoever every time i drive it everyday.
    Loves it, the rubbers show no sign of damage.
  8. #188
    Brad
    Central coast
    top stuff. getting my car ready to engineer. need the brake upgrade, and want more steering lock. but dont have much coin at the moment. thanks
    might just run s13 coilovers and just leave the stock strut tops for a while
  9. #189
    Kevin
    Camden
    glad to here you guys arent having troubles. thats why i made sure i said 'may' go through the rubber as i have never personally seen this, only heard rumours.
    question for those who have used bluebird tie rods: i ordered some tie rods today from my parts supplier, just asked for 83 TRX tie rods. got them, they fit the rack ends fine but they arent a good fit for the s13 stub axle. which model bluebird tie rods are people using? maybe the later FWD ones? if its any help, the ones i have are marked left and right, they have a kink on both sides.
  10. #190
    nah nah...use bluebird rack ends....ra40 ra60 ma60 tie rod ends...
    im not sure what bluebird...i just asked for early bluebird ones...
    Adam
  1. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
