Read the first post in the above link.
Is it possible for me to use S13 tie rods with this setup?
Just read it, thanks man, question answered.
Not sure if this is mentioned somewhere in the 17 pages of nonsence, lol, but mx83 cressida rackends and tie rods can be used. Side by side mx gear is chunckier with a larger ball joint and is the perfect lenght with lots of adjustment.
This setup is different to the ra60/bluebird in terms that the rackend is very long and the tierod shorter whereas the ra60/bluebird is almost 50/50 or slightly longer tierod
I'll also add but the cressida spare parts seem much harder to get then ra60 r/e and bluebird t/r.
ADM 4AGZE SPRINTER
JDM SR20DET TRUENO COUPE
ae86s love since 2004
by mx83 do you meen mx62 or whatever the old one is
No, by MX83 he means MX83. Latest model Cressida to come to Aus. Conceivably, MX62 could be the same, a quick check would reveal that, but I doubt it.
Repco don't stock any Silvia bits either which is a pain.
wow....i cant believe this is still going.....
Well I finally got all my gear in and a wheel alignment done but the whole front end feels a little weird.
The front is Slammed hard which I'm not too keen on since the back isn't need to lift the front drop the back n go get another wheel alignment, I also lost my steering
(the wheel is now upside down cause the rack slid all the way through and when we got it back in the wheel had spun 180!!!!)
I guess I'll keep playing around with it til I get it right
I've got three degrees of camber 1 degree of castor and i can't get to full lock coz it scrubs time to pull the front guards off n give them a bashing then some pressure pack black.
Leigh
omg why do u run shuch little castor? lighter steering? more lock?
are you talking about ae86 leigh?
what do you mean by "weird"?
i jsut put s13 stuff in my ke70 (i guess it can be considered the same as ae86) i havnet touched the castor arms, i assume they are set at zero, the camber tops are maxed out negative, and it feels pretty good to me. the coilovers are stuffed so its a little scary goin over bumps, but on smooth ground it handles like its on rails.
what size wheels/tyres are you running?
- Blaise Pascal
