Page 36 of 42 FirstFirst ... 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 LastLast
Results 351 to 360 of 415
Thread: S13 coilovers into AE86
  1. #351
    Sprinter-Saurus
    Are you some sort of retard or what ?! <_<
  2. #352
    Senior Member EVOSTi's Avatar
    Kevin
    Camden
    i cant see the problem?
  3. #353
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    try winding the coilover as high as possible while the weight of the car is on the spring.
    p.s. no such thing as too low.
  4. #354
    Zac
    Sunnybanku
    LMAO, no actually i think his english is just bad. and maybe he just forgot to mention he already wound the coilover all the way up b4 installation........ maybe <_<
  5. #355
    Veteran johl's Avatar
    Johl
    i'v searched this thread about 2 times now and cant find anyone that has said what steering rack they used? stock sprinter? sprinter with power steering? or s13?
  6. #356
    Benn
    gold coast
    original conversion uses standard rack(P/S or non-P/S), but there's also rack end/tie rod combinations listed for aw11 racks and silvia racks
  7. #357
    Dave
    what brand coilovers are you using, and are they base adjustable? KEI office coilovers are the ones to get for this conversion, they are all uber long.
    steer away from anything that isnt base adjustable.
    i have JIC coilovers in my ke70, and i have the base adjusted almost all the way up, and the spring seat about 2/3 up the thread (so making it 2/3 max height i guess) and it makes the jacking seams of the car about 140mm off the ground. this is with 200mm 11kg springs, i just ordered some 250mm 8kg ones so i can get the spring seat in a more user friendly position. and so i dont jar my back from the 11kg springs
    - Blaise Pascal
  8. #358
    Oldschool Member
    Jul 2007
    Have any of you had problems with the centerline of the hub/wheel assembly being shifted forward a bit? it seems that on my setup the whole assembly got pushed forward about an inch and is causing the tire to rub on the front bumper. I tried adjusting the Caster rod but had no luck with problem....
  9. #359
    hmmm... what are the chances of removing all non relevant posts (including this one) from this thread to make it easier to browse?
    18 pages and most are just rubbish posts? Would make it more of a "technical" article...... more relevance, less 2c adding...
    /end 2cents
  10. #360
    Try
    I think it condenses most of the info found in these 18 pages.
  1. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
