Page 3 of 42 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 415
Thread: S13 coilovers into AE86
  1. #21
    Ferny Grove
    no, i like to steer clear of fabricating stuff!! bolt in FTW!!
    looks good, are they yours?
    i liked the "full" S13 conversion as you get a track increase as well plus the brake upgrade, even if you just use CA brakes it's still a decent upgrade over ADM stuff.
    wouldn't converting S13 stuff that way be the same as using a weld on coilover kit?
    hows does the shock height adjustment work?
  2. #22
    Scott
    Coombabah
    hey im just curious, im a bit dumbfounded as to how u actually gain more lock with the s13 setup, i think i have an idea but i still cant figure it out, ive been lookin at pics of both setups but its got me, ohwell cheers, as i will be doin this upgrade to go with my sr20 i mainly want it for the brakes and the fact i can get the coilovers easily enough lol
    cheers in advance mate
    scott
  3. #23
    Ferny Grove
    ^^ it's all in the steering arm, they are shorter like an AE86 p/s arm.
  4. #24
    Oldschool Member
    Mar 2006
    Jody
    St. Philip
    Sea View
    Barbados
    Nahh not mine i wish those are some of the Kei office coilovers off Yahoo japan auctions
    but Im not really asking which u prefer i can understande why u wanna use s13 stuff but im wondering if u guys think it can work
    as far as how shock height works u just turn the bottom but instead of the one under spring it lowers or raises shock into the bottem casing thereby lowering without compressing spring
  5. #25
    hey stomp86, have u fitted the silvia lca's to the sprinter crossmember? did they fit?
    on a funny not i priced up some brakes and hubs and s13 lca's. the parts guy is charging $95 for a rigth hand lca and $125 for a left hand side one, he reckons that left hand side ones are hard to come by cause everybody damages them and there in demand.
  6. #26
    Oldschool Member
    Apr 2006
    i am running s13 control arms, just gota drill out the hole where the lca and crossmember meet
  7. #27
    Mar 2005
    Im very happy about this as I was racking my brain on how to do this and pass engineering....... looks like that will be a whole lot easier now...
  8. #28
    Rob
    Moorabbin
    the whole LH LCA more $$$ is true, every homo with an s13 drifts on the street where else do you bend control arms except gutters!
  9. #29
    Senior Member EVOSTi's Avatar
    Kevin
    Camden
    is anyone aware of a balljoint that presses into the 86 arm but has the correct taper for the s13 hubs? ive heard rumours of TR magna, is this true?
  10. #30
    Senior Member rallystanza's Avatar
    Jeremy
    Vic
    Straya
    Last night i compared the lengths of a S13 LCA and a standard Ae86 LCA.
    The S13 LCA was about 40mm lomger, thats a lot longer, however the S13 LCA was only about 10mm longer than a sigma arm.
    Can those who have use a standard S13 LCA withthis conversion detail how much camber they have now, i would have though it would be exessive.
  1. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
