<div class='quotetop'>QUOTE (EVOSTi @ Jun 20 2008, 12:33 PM) </div>Cheers man might have to take u up on that the way things r turing out atm....
If your going to use the breaker bar option to get the top nut of the shock shaft, put the vice grips up at the highest point of the shaft, otherwise your going to have a whole load of problems in the future.
heres some roll center adjusters for s13!
price isnt too bad for what youre getting, i plan on getting some eventually.
I'm a little confused...there is much talk about using the early bluebird tie rods such as an early 80's TRX..but Gilly posted that he then used RA40 tie rods...am i right in saying that either the bluebird or the RA40 tierods can be used?? which one is better/recommended??
use bluebird
as in TRX bluebird??
use whatever is long enough. which depends on what rack end and lca you go with.
78's
just to show you guys about the myth of ridiculous camber, i have test fitted my 15x7.5 -5 ssr to the S13 front end, ive got JIC 8kg/mm coil overs, Cusco tops, Bluebird tie rod ends (ra40 tie rods i belive) and all i need now is to just get myself a 14mm drill bit.
I ve just finished fitting s13 coilovers to my ae86 and i have put myself into some trouble...
I used
Tein HA coilovers from s13
ca18 brakes
s13 lca
s13 tie rods and ends...
The car ended up ridicullusy low, almost scratching the ground...
Also my tires, ( 6x14 advan wheels 6 offset) are rubbing fenders A LOT. I have widened my fenders but the tire is rubbing inside of it...
My last hope is that i can adjust the coilovers a little more high but i believe that i have set them already in max height...
I m really disapointed at the moment.
Any ideas that may help would be good...
Thanks.
