Page 5 of 42 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 415
Thread: S13 coilovers into AE86
  1. #41
    got it aligned today...got camber set to 2.5 which is more then u think...now it rubs on guards real bad...getting guards flared (read : hammering out guards) tommorow but all in all its pretty damn good there is no chance for any rubbing anywhere except guards so im pretty happy...probably up for some 8 inch wheels on the front soon as soon as its all sorted...btw people at alighnment places will look at you funny if u ask for like 6 deg camber...
    hey gilly, how much travel do u get out of your coilovers...do u basically have to set them to max height to get the car up enough to not be in the guards?
    Adam
  • #42
    Ferny Grove
    yep not far off full, go back to the first couple of pages you can see it there.
    8kg springs = not much movement so travel not a huge issue, however seeing you asked i have no shit about 2 inches of shockie travel before it his the coilover bumpstop, so more than enough.
  • #43
    So stomp,
    Does your current 2.5 deg of camber make use of the slotted upper mounting hole in the coilover? Or are the two coilover mount bolts in their normal position and the camber adjusted only with the strut top?
    Thanks
  • #44
    yeah coilie is pulled out to minimum camber setting then adjusted with strut top hat...i dont think its on full adjustment either...i still havent driven the car for any significant ammount of time as it rubs real bad....but ill post after today because i should have it finished tonite...
    Adam
  • #45
    Thanks Adam. That sorts out some questions I still had.
  • #46
    Ferny Grove
    did anyone change wheel studs at all? from nissan to toyota ones? i just want to know which ones i should use. i don't have any toyota studs here to compare them with, can someone tell me if they look like they'll fit.
  • #47
    Senior Member rallystanza's Avatar
    Jeremy
    Vic
    Straya
    Gilly, the studs will be able to be changed and in my opinion Toyota has better thread pitch at 12x1.50, as it is courser and its harder to cross thread. I had a stanza rally car and was changing a lot of wheels and fucked sooo many studs because of the finer thread at 12x1.25, being in a rush and all.
    You can change to toyota and i would, as you will also have toyota all round again.
  • #48
    Joel
    Blackwood
    ^^^Werd up.
    It sucks having different wheel nuts for the front and rear on a hachi.
    Toyota studs FTW
    AE86 4AGE "Slowly but surely"
  • #49
    Senior Member EVOSTi's Avatar
    Kevin
    Camden
    stomp, without going back through the thread cause my net is stuffed, are your coilovers adjustable height with the bottom mount, or only with the bottom spring perch? if only with the spring perch, are they all the way up just to give acceptable ride height?
  • #50
    Jeremy
    Vic
    Straya
    bottom brakcet height adjustable.
    Means you can adjust the heaight and preload independantly. this style is FTW!!!!!
    Jez
    Oh and Kev, your internet is a phag.
  • Page 5 of 42 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
    1. S13 LCA's S13 front coilovers and AE86 rear coilovers
      By Brendan in forum Cars or Parts Wanted
      Last Post: 8th April 2010, 01:11 AM
