i just measured an s13 arm and its also 40 cm exactly...and much easier to get then jzx ones
from the furtherest point to point = 40cm , measured in car this morning.
i don't know about the cressida arm, but if you find out it is let me know so this can be updated.
share the wealth!!!!!!
hmmmm there you go then!!!! the only drama would be the bush end it may be too wide to fit in the crossmember, there must be a reason why they aren't used. let me know if it fits the x member, i might pull my jzx arm out tomorrow and measure it again.
as far as i know people dont use s13 ones because of excesive camber...but if they are same as jzx ones then it should be fine...the camber on your car looks good...not over the top
they are to wide at the crossmember end to fit, i've just read, ad was that measurement you gave from the furtherest point to point, as s13 arms i'm sure a re longer than that.
ive got s13 arms in mine
uncut ones? how did you make them fit?
i bought them that way they had s13 written on them and bolted up easy enough no sign of welding i can see
i'll ask about them tonight if i can and post my findings up later
edit: added some more pics on page one
has anyone considered using a coilover from s13 or another macpherson strut design, cutting off the mounting plates and welding bottem of coilover ontoo bottem of ae86 stru to create a coilover setup similar to the more expensive japanese setups like kei office where shock height adjust independent of spring
so from this
to
