do you want to explain what you want to do a bit?
i have very very limited knowelege of how to go about setting this up and what parts would be needed,
if someone has done this throw some links or info my way, (yes ive searched).
cheers jase
id say there would be quite a lot involved such is drilling into the cylinder head and finding room on it for the injector. The 16v has very little unsed head space so im assuming the 20v is going to be worse.
Hasn't bosch developed technology on this. Check there web site>
i havent seen it on anything other than diesels
sorry guys, typo on description.
im after info on direct ignition, using SR20 igniters ect,
anyone?
aftermarket ecu easy
iirc the 1g ones fit
sorry for the ignorance, but i get the after market ECU,
but what did you mean by 'iirc the 1g ones fit'
if i remeber correctly the 1ggte ignitors fit
You can use the coil-on-plug ignition from a 1zz motor from a new celica. Not sure of the modifications required to fit it, but i know that they have been used before.
