Page 10 of 97 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 60 ... LastLast
Results 91 to 100 of 962
Thread: Biggo's bagel as Carina!
  1. #91
    Davey & Riki-lee
    South Australia
    Seaford SA
    Fucking good job man! Time for new rotors.
    Our introduction - Click here
  2. #92
    Veteran biggo's Avatar
    Nick
    Noosa
    they will be fine after 5 mins in bed with me
  3. #93
    Veteran slydar's Avatar
    Dimitri
    sussy is wack. but at least it is part of a very strong diff and drive shafts.
    broken cars suck, and all our cars handle shit anyway..
    78's
  4. #94
    Veteran driftke70's Avatar
    Ryan
    Buderim
    plus once its low and stiff not that much matters unless your sliding over 80 clicks, little rear toe never killed anyone.
    wheelfriends.wordpress.com
  5. #95
    Senior Member xsoarerx's Avatar
    Logan City
    lol i had something like 12deg of rear toe to match the -4.5 deg of camber... Sweet!
    you can buy all the replacement bush's for the rear end (MA61 is what to look under) if you can be bothered to change them... droping the rear end is like moving a fridge....
    but heaver!~
  6. #96
    E-Famous (Remeber your roots)
    Rear end owns. Same as mine by the looks?
    Coming along nicely! I can't wait to see more of this.
    marvis.
  7. #97
    Tigh
    Vic
    Southside
    Like yo work.. A lot.
    Just wanted to ask about how you did the rust repair on the guards. Before welding in the new metail did you lip the gaurd edge so they overlapped? Or how did you do it? About to do it on mine..
    Peas
  8. #98
    Nick
    Noosa
    yes and no, the top 2 squares are just sitting there welded on. the long edges of the other 2 have lips on them, basically just make the peice a lil longer and grab some thick plate, hacksaw a line like 10-15mm and use that a lipping tool. once you got it like 90* degress you can just hammer it under and it will sort it self out. Worked beaut on the boot lid too.
    RE the rear end - its the same as MA61/xZ20/RA65 etc etc etc
    Ive had a look at it, will leave it till im done with the body but really theres not alot you can do, fair sure commo offset bushes are a bigger diameter so that wont work. old dattos use a weld on mount kit, its far to funky for me to deal with tho.
    And john - that f series diff i have is like the weight of a t50! only smaller hehehehe
  9. #99
    Tigh
    Vic
    Southside
    Cheers mate. Unstood it all except the 90 degree part.
    If it is a Z20 etc rear end jump onto supraforums.com.au or the likes some guy in NZ makes a bushing kit. Factory LSD!? Miss my MZ21
    Edit: it's not a Z20 rear end as there double wishbone from memory.
    MA71 = MZ20
    MA61 = MZ10 maybe!?
    Not sure if that guy made *A61 bushes..
  10. #100
    Nick
    Noosa
    The 90 degree part - once the lip is bent that much with the lip tool you can then just hit the lip with a hammer. The tool is used to keep the same amount of lip all the way along.
  1. Biggo's offtopic off topic
    By biggo in forum Offtopic Discussions
    Last Post: 31st March 2013, 10:37 AM
  2. BIGGO VS THE WORLD
    By Vaughn in forum Youtube Chan
    Last Post: 12th November 2011, 04:22 PM
  3. Biggo's slimey 4agte
    By biggo in forum KE70 / AE71 Owners Forums
    Last Post: 8th May 2010, 05:14 PM
  4. Beau and Biggo are drink!
    By Beau in forum Offtopic Discussions
    Last Post: 6th February 2010, 03:35 AM
  5. Help biggo fix his 86!
    By biggo in forum Cars or Parts Wanted
    Last Post: 11th March 2009, 06:57 PM
