Results 1 to 6 of 6
Thread: rack end replacment
    Jason
    Gold Coast
    im about to change my rack ends (theres alot of play in them),
    never done this before so is it a basic job or is there anything special i should know before attempting it?
    cheers jase
    Ferny Grove
    nah pretty simple.
    take off your tierod ends from the rack end
    remove the rack boot
    bend back the lock washers at the rack end (you'll see what they are)
    undo the rack end and screw in your new one, make sure to reuse lock washers
    refit old boot (or use new ones repco universal rack boots fit perfect.
    refit tierod ends
    do wheel alignment.
    while they are off you can fit a couple of washers between the rack end and rack housing for some extra lock if you are that way inclined, just make sure there is a decent amount of thread still in the rack itself! and use loctite on the rack end threads as you can't reuse the lock washers when you space the rack ends out.
    hope that helps.
    Jason
    Gold Coast
    it does thanks very much.
    i already have power steering arms, would u say it would be worth using spacers?
    Ferny Grove
    i don't really know to be honest!! i've never used ps arms or the spacers or even both. i know Dave (AJPS) uses both, there is a picture of the lock obtained in his members ride thread.
    Terry
    Ipswich
    there is not much thread in the rack end so I think spacers would be unwise. the risks probably dont match the benefit. carefully check the rack boots for splits as theya re easy to replace whislt apart. if you need them, I have new ends & boots in stock along with new lock washers (which are essential). see ww.roadandtrack.net.au if interested .
    Alex
    St Lucia
    For one of my cars I went to get new boots and they were like $10 each or something but the one-size-fits-all boots work just as well and are only like $3 each. Also mark how far the thingys (are they rack ends?) screw on so you won't need a wheel alignment.
  1. Rack end help.
    By sam92 in forum Technical - Questions
    Last Post: 7th November 2012, 11:26 AM
  2. WTB ke70/ae86/ae71 tube things between rack end and tie rod end
    By ke70dave in forum Cars or Parts Wanted
    Last Post: 25th June 2010, 06:01 PM
  3. rack end and rack bush for ae86 power steering rack
    By quoccy in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 12:58 PM
  4. r/h rack end
    By lewwy in forum Cars or Parts Wanted
    Last Post: 16th October 2007, 04:44 PM
