string
hey guys tryed searching but nothing came up for this, just wondering how to remove the glass from my hatch without damaging it.
any help would be great.
thanks
sab
string
pretty sure its just glued in with hot strips or sumin. u can cut it off or try to push it out or heat it up or sumin honestly im not sure but if u want a sure fire way to get rid of it... remove hatch... attach hammer... that'll get tha job done REAL quick
string? u mean like taking off side strips of the car with fishing wire, same principle? or am i completely off here?
haha there wont be any hammers coming close to my glass anytime soon hopefully. i might give the heat gun a shot though.
thanks for the replys
sab
Just push the seal edge over from the inside. The hatch lip will probably crumble away with rust and then the glass and seal will come out easily.......
Hahahahhahaha Dave you love for Evan is blinding you.
You use string or rope to re-install the windows.
As mentioned you need to slowly and gently pry the seals out from the inside, use sturdy screwdriver to get up and under the seals from the inside, then slowly work your way around.
Hint: start in a cnr, and dont take the hach off, makes it much easier. Also peeling back the seal from the outside and using soapy water can/will help.
Be patient it will take time and some convincing if youve never done it before.
Steve
Insert witty comment here....
if u have no need for the glass get a hammer and go nuts
helps if you have somone to apply pressure where you are easing the seal out. you want the glass to come out through the top of the hatch. its quite easy just be patient and work your way around.
windscreens o'brien
thanks for the replys guys lot of good info there.
will let you know how it goes tomorrow
thanks again
