Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: my ke70.. wat next?
    Adrian
    South australia
    Mawson Lakes
    Default my ke70.. wat next?
    hey all.. bought a ke70 rolla.
    has a 4age bigport with t50 box.
    now the engine has oil feed and oil return lines blocked off where a supercharger/turbo was..
    im wondering wat i can do to give it some more get up and go?
    if i went turbo/supercharger wat would i need?
    i dont know alot about these cars so all help is greatly appreciated!
    regards
    A
    Parky
    How much $$$ you got to play with?
    Turbos probably easiest,
    best of selling that 4age getting a 4agze,manifold and turbo.
    4agze have forgies and stocko ecu can run a turbo motor,
    Adrian
    South australia
    Mawson Lakes
    how do u tell if its a 4agze motor?
    and i got as much as i need to spend
    just need some direction.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    you find out by putting a turbo on it, then winding up the boost untill it blows up. thats how you find out.
    FTP.
    Adrian
    South australia
    Mawson Lakes
    massive help mate! (N)
    anyone know? as i dont wanna be blowing engines!
    also how to tell if ecu is from 4agze?
    Veteran johl's Avatar
    Johl
    usually the rocker covers will have super charger written on them if it is a gze motor, however these are easily and often changed. just pull out the ecu and have a look. it will have a sticker on it saying what engine it is for. ecu's are usually easy to look at, just have a look from underneath the glove box.
    yeh as previously stated it is way more worth your while starting off with a gze. so i would suggest leaving the bigport in your car and buying a gze and put it on an engine stande and building it up from there. bang for buck, turbo is the way to go if ur chasing power. but if you have driven one with a super charger you will know how good the instant torque is.
    where abouts do you live? i'd suggest going out and atleast be taken for a drive in both turbo and supercharged options, and maybe even convince them to give you a steer.
    if u want anymore info just ask away
    Adrian
    South australia
    Mawson Lakes
    awsome info man!
    i live in adel.. would love to c the difference between turbo and supercharger..
    will sus out my ecu on the weekend..
    i got 2 ecu's one in the car and one that was in the boot with extra pieces.
    Adrian
    South australia
    Mawson Lakes
    still can find out if it has a 4age or a 4agze!!!
    Dan
    Vic
    Western Subs
    one way you can but you wont like it...
    remove the head... and you'll be able to see the pistons and theres your answer
    it will cost you....
    120 headgasket (mayaswell chuck a TRD 0.5mm one on)
    150 head bolts (i dont care what anyone says i always replace after taking off the head)
    150 - 500 torque wrench (if you dont have one get one a wise investment!)
    coolent & oil timing belt if it hasn't been changed in the last 100,000km oil and air filters
    and prolly a full saturday
    thats what i would do.. but im more inclinded to think you ahve a 4AGZE and the person you brought it off i dare say blew the turbo or was on P's and didn't want to attract to much attenion so blocked off the oil lines etc.. and was going to upgrade when the time came
    also check your ecu it would have a sticker with 4AGZE on it or very least a serial that you can google
    enjoy i hope this helps
    . h i t o r i k o .
    Adrian
    South australia
    Mawson Lakes
    i found this number on the underside of exhaust port 4..
    4A
    0577318
    mean anything?
  1. wat are these and how do i get them?
    By sxg01d in forum Cars or Parts Wanted
    Last Post: 24th April 2010, 05:15 PM
  2. show me wat you got
    By wntdae86 in forum Melbourne & Vic Events and Discussion
    Last Post: 13th March 2010, 11:53 PM
  3. wat kind off cable can i use for my 4age ke70
    By ghetto ke in forum Technical - Questions
    Last Post: 28th August 2009, 11:29 PM
  4. wat shocks to use??
    By dyso in forum Technical - Questions
    Last Post: 10th September 2006, 10:03 PM
