Results 1 to 10 of 15
Thread: cams for turbo 4a
    Senior Member slideways's Avatar
    Tristan
    Default cams for turbo 4a
    yo peeps,
    wondering what the recomendation for cams are in a turbo application.
    also what valve springs to use, and i will also be converting to solid lifters from a 1SZ yarris motor.
    cheers.
    Jonathan
    Generaly, the stock cams are best for turbo. Untill you start making serious power and want to look at every aspect of your motor in detail, by which point you would have collected more ideas.
    I am guessing standard cams, springs and shims are fine for turbo use. Unless you want to increase the normal rev limit.
    Senior Member 45aken's Avatar
    Marko
    Jonny,
    you wouldn't even recommend a mild 256 with higher lift?
    Jonathan
    If I was building a turbo car and saw some mild cams on ebay, then I would consider yes. But it comes down to cost effectiveness. More critical would be the actual turbo.
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    i have kelford cams in my turbo 20v (the motor hasnt been run yet) but kelford do a set of cams specificly for turbo 20v's and turbo 4age's its not up on there list of cams but if you email them they will give you the specs
    i do however think that what JR is saying is a better way to look at it, it depends on how far you are going with the build, i went all out and pretty much replaced everything, but if your just going to turbo a ze or something i wouldnt worry about cams
    maybe spend alot of time researching what turbo to run or spend the money on port work
    Quote Originally Posted by 350hp4agte View Post
    thats if u even get a response from kelford...
    3 emails and still no reply...
    might just ring them instead when i get the chance
    Mason
    Salisbury East
    Hey slideways
    I can get you some cams,
    I can also supply you with valve springs to suit.
    PM me with your engine useage, power revs etc.
    Tristan
    well so far i'm running a 7 rib block, stock ze ae101 internals, a bigport head with standard ze gasket. a custom 3 odd litre plenum. 600x300x76 pwr cooler. an off the shelf bb t28 with 64 a/r.
    the head has been cleaned up a bit
    also have an ebc on the way to reduce boost creep.
    i have a bit of money to spare, so i was wondering where the money might best be invested.
    and figured i might fork out for a set of cams.
    is there any limitation to lift and duration because you forcing air. remember reading something about blow through???
    underwood
    qld
    jimboomba
    ecu mite be a better option than cams, injectors also a better option or even cam gears to stop the old blow through, a good fuel reg
    actually a good fuel system is a better idea i recon, injectors fuel reg and a good pump ie 044 bosch and an ecu to turne it all in
    Veteran johl's Avatar
    Johl
    n/a cams
  1. 4a shit, X members,Cam gears, Cams, HEAPS OF SHIT!
    By lolwat in forum Car Parts For Sale
    Last Post: 13th December 2012, 08:56 AM
  2. 4A Turbo bits
    By Nikkojoe in forum Car Parts For Sale
    Last Post: 25th March 2011, 11:21 PM
  3. turbo 4a sellup
    By pen15 in forum Car Parts For Sale
    Last Post: 31st July 2010, 09:27 PM
  4. Best 4a engine for turbo conversion
    By dan_9 in forum Technical - Questions
    Last Post: 25th May 2009, 06:36 PM
  5. 7MGE injectors for turbo 4A?
    By Mattysshop in forum Technical - Questions
    Last Post: 26th August 2006, 11:43 AM
