Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
Thread: ideal computer?4agte..
  1. #21
    I love my haltech, anyone who says they are shit is a tossle smoker, that being said i think it is up to the individual in the end as to what they buy, i think just about every computer discussed here would do most of what you would need on a 4age.
  2. #22
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    I'm running an autronic SMC, easy to tune, easy to install, only down side, retail prices are a bit exy. Cheaper than motec, pricier than Haltech, but IMO, worth the $$$ after seeing a hi-po 4AGTE have nothing but trouble with an Haltech.
    Best advice, Find a tuner and go with what they sujest, as they will be doing the work on it, they need to know what they're working with,
    eg. no good having a Wolf 3D if the tuner isn't to crash hot with them but a wiz with motec's.
  3. #23
    Anthony
    MJ86: does your haltech connect directly to your toyota CAS? reason I ask is I noticed they had to use a reluctor adapter box on beau yates car (E11V2/SXE10 3SGE), which I was a little suprised at.
  4. #24
    Senior Member crackett's Avatar
    I have a GReddy E-Manage Ultimate brand new, still in box which you can have for $950
  5. #25
    andrew
    yeh haltech doesnt like cas, so dont use the cas. Its a great ecu.
    that adaptor box from haltech is a wave converter its ment to make reclutor style cas's work with the haltech but it didnt work for me so i went with the halleffect magnet sensor and its perfect.
  6. #26
    Smile
    No Anthony, i`m still using the distributor, seems to work alright for now, may change it later, and i`m running an old E6s.
  7. #27
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Is this still the case joe with newer models?
  8. #28
    thread dig... but nah the sprint 500 is perfect with the cas now.
    The only reason you'd go the 1000 is for the 32x32 fuel maps.
  9. #29
    Mar 2013
    Mirko
    Yeah got ps1000 if it ever arrives
  10. #30
    Veteran Skylar's Avatar
    Ken
    Didn't I post the answer to Nikkojoe's problem in this thread somewhere?
    The e8/e11 is fine for 4a CAS as long as you wire them properly. That means split the three white signal 'ground'/return wires at the CAS and run two minus wires to the haltech harness as it says in the manual and you'll be fine. If you leave it as it is and used the single joined return wire (white) in the toyota loom and connected the trigger and home minus wires together you will get crosstalk across the two sensors and the ECU will get mixed messages and things get fun.
    Matt, the 32x32 is max capability right? You can add, delete and move rows/columns as you wish, right?
  1. Ideal Compression Ratio??
    By Deeken in forum Technical - Questions
    Last Post: 3rd August 2011, 12:30 PM
  2. what dizzy and computer to use on 4agte
    By mick in forum Technical - Questions
    Last Post: 21st March 2010, 11:10 PM
  3. Ideal 20V water temp?
    By Vezza in forum Technical - Questions
    Last Post: 27th August 2008, 11:32 PM
  4. 4agte computer
    By cr86zy boy in forum Technical - Questions
    Last Post: 9th May 2007, 03:21 PM
  5. tell me what u think the ideal engine is for a 86
    By roger roger in forum General Topics (No Technical Questions)
    Last Post: 31st January 2007, 07:44 PM
