Results 1 to 7 of 7
Thread: clutch?
    Senior Member riceburner's Avatar
    Default clutch?
    hi guys, need some help...
    driving to work this morning and i start to notice a strange noise. sounds like someone is trying to strangle a cat. happening whenenver i press the clutch pedal down.. drove the car all the way to work and will have a look at it afterwards... im thinking either low fluid or parhaps one of the clutch master/slaves are on the way out? any ideas at this stage. havent had a chance to look at it cos i was in my suit and ill be stuffed if im getting grease on me before work!
    Insert witty comment here....
    Veteran shift_rook's Avatar
    SE Burbs
    thrust bearing??
    Jonathan
    Well if you wear a suit, you can just pay someone to fix it. Done.
    Clutch thrust bearing. Gearbox has to come out.
  • #4
    thats what i thought... itll be ok to drive it in the mean time til i can get it into a shop?
  • #5
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    well a t50 is a piece of piss to take out try doing an sr20 clutch omg struggle street should take the better half of an hour to take out the t50 after work hours good luck
    the dyno pull to 300rwkw
  • #6
    Mate if your thrust bearing is gone, it`s a good bet that the clutch itself will need replacing. A new clutch kit(standard) should not set you back any more than $100 - $150 if you know where to look.
  • #7
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Mine did it for a few months when my new clutch had been in for about 2 months. Has since gone away. Probably ratshit now.
  • Similar Threads
    1. Replies: 1
      Last Post: 19th October 2010, 04:30 PM
    2. altezza beefed up clutch new with clutch disc and carrier bearing
      By Celica RA45 in forum Car Parts For Sale
      Last Post: 15th June 2010, 11:15 PM
    3. Replies: 4
      Last Post: 4th January 2010, 09:42 PM
    4. wtd t50 clutch fork clutch t18 rear bar etc
      By wanabdrifta in forum Cars or Parts Wanted
      Last Post: 13th July 2009, 11:49 AM
    5. Melb: Pedal assembly, hard clutch line and clutch master
      By stahlz_ae86 in forum Car Parts For Sale
      Last Post: 31st March 2009, 07:04 AM
