Results 1 to 10 of 14
Thread: top strut bolt
    Default top strut bolt
    how the hell do i get it off? i bought a set of struts to suit e7 off here that came with lowered springs. i only want the springs. how do i get the springs off and then put the springs onto my struts. i know how to do everything else i am just fucked if i can get that top bolt off. any help would be saweet.
    Veteran shift_rook's Avatar
    SE Burbs
    have to either use a set of multi grips or spring compressors to get tension off the spring then just undo the top bolt... make sure you get tension off the springs, my fathers mate lost his teeth from undiong it under stress
    Jonathan
    Rattle gun.
    Or clamp the spring top hat in the vice somehow, then use your socket and strong bar.
    On one occation, I welded the spring to the top hat, then clamped the spring in the vice.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    how loose are the springs?....are they cut springs?...i took out my cut springs on my ae86 without the top hat comming off...
    spun the spring out of the bottom plate it was sitting on....came out like nut on a bolt
    dose
    they are proper lowered springs in the ones i bought but they are running un-captive, so there is no pressure on the strut top but i cant get it undone. the ones in the car i tried losening the top bolt while it was in but i can get either of them. omfg i want to kill someone, its so frustrating i done the back and then went to do the front and cant get them done. my car looks like it should be on boostcruising. lowered at the back and not the front. boostgangsta ketto? i dont think so. fuckkkkkkkkkkkkkkkkk
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    dude, take it to a workshop and get them to use a rattlegun on itunless you have one yourself
    thats your best bet
    MY JZX83 (clicky)
    but im to lazy. fuck oh well. i will ill do it another day cause i have to go to work now. fuckkkkkkkkkk. yay for positive camber!!!! ill just go to pedders and get them to change the springs for me. cbf doing myself. pissed off now. fucking heap of shit.
    ps. no word on archy yet
    Veteran johl's Avatar
    Johl
    dude dont take it to pedders. they are gay. just go to a small workshop, where the guy that works there is the boss, take in a 6 pack of beer and ask him to undo the nut for you and have ur other struts there also and change them over, and get him to do them back up. will only take 2 mins tops
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    take it to marty?
    real men use lockers, LSDs are for posers< lol tops... sorry for randomness lol
    and dont forget to help him drink the piss
  1. Gas strut between strut top and engine
    By hugh in forum Technical - Questions
    Last Post: 26th August 2009, 11:09 PM
  2. wanted ae86 r/h/f strut top
    By buster86 in forum Cars or Parts Wanted
    Last Post: 20th January 2009, 06:26 AM
  3. Strut top plates - Brisbane
    By donp in forum Cars or Parts Wanted
    Last Post: 30th August 2008, 09:00 PM
  4. Broken Strut bolt
    By patience in forum Technical - Questions
    Last Post: 27th April 2008, 10:07 PM
  5. Front Strut top bolt
    By Yellow Keto. in forum Technical - Questions
    Last Post: 23rd November 2007, 10:24 PM
