installing a GT4 radiator
to start with, I made some custom lower brackets out of sheet metal and some U-bolts.
I cut the old mounts off and grinded back the remaining metal.
cleaned up the brackets
mods for the top brackets. flattened out where the drivers side bracket needed to go, drilled new holes and weleded nuts on the underside
top mounts done
finished! its like it is meant to be there.
