Results 1 to 10 of 10
Thread: Max Speed Vs. RPM
    Veteran blair's Avatar
    Blair
    SEQ
    Default Max Speed Vs. RPM
    Stock bigport running twin webbers.
    S series Diff (3.9's)
    running less than 20deg locked advance... thinking of upping to 30 now that ive sorted a bit of cooling (carbs were tuned for 32 a long long time agooooo)
    what would you expect in each gear? and at what rpm?
    80 is the most i pull in second and thats at just over 6k according to my super sweet jumpyaround stock tacho...
    and 3rd just feels like poo above ~120 ( 5k?)
    and it honestly feels like it doesnt wanna pull past that/i dont wanna push past that... would this be alot to do with the timing @ those revs?
    opions please.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    sounds still like standard
    just get a better diff ratio?..
    dose
    Moderator Sam-Q's Avatar
    Endeavour Hills
    not allowing for my diff ratio compensation at 8000 RPM or so I get the reported following :
    1st- 50km/h
    2nd- 105km/h
    3rd- 150km/h
    4th-?? havent found a long enough stretch of road, I have had the needle hit the dash before on a somewhat short stretch though
    Senior Member doony's Avatar
    Dan
    i remember my stock bigport and stock t series would pull similar figures to samQ's
    dont think i got that much out of 2nd though maybe 100 or so.
    this was at 7,900rpm or whatever the standard redline is for bigports.
    Or driving in a wolf pack.
    Endeavour Hills
    yes I must say my tacho I know isnt tottaly acurate, it shows around where 8200RPM should be when I bounce off my 8600rpm limiter.
    Now all I need to do is find a very long quiet stretch of road, on private property of course
    Rob
    Moorabbin
    Hey guys,
    Here is a spreadsheet I made to caluclate revs and speed. You can change around the gear ratios, final drive etc and see how it might affect your shift point.
    edit:
    Sorry thats just a pic...
    Here is the spreadsheet
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    ^ genius! thanks man.
    Endeavour Hills
    interesting, that really shows how big a gap there is between 1st and 2nd. This is why a more peaky engine with a high power can be slower without the right ratios to back it up.
    Now I wonder what would get a higher top speed for many of us 4th or 5th gear?
    thats an awesome spreadsheet man!! good work.
    Blair
    SEQ
    ok so i thought 6500 sounded hot with induction...
    just took it to 7500 at 95kmish
    had a grin on my face for about 5minutes!!!
  1. Ke 70 5 speed starter fit 4 speed box
    By drift addict in forum Technical - Questions
    Last Post: 21st February 2012, 11:15 PM
  2. Surge @ Low RPM.
    By 4agejet in forum Technical - Questions
    Last Post: 4th March 2011, 10:06 AM
  3. Maximum RPM?
    By slider rx7 in forum Technical - Questions
    Last Post: 19th September 2008, 06:56 PM
  4. ae86 drifting on RPM
    By grape_moosha in forum Offtopic Discussions
    Last Post: 29th June 2008, 06:31 PM
  5. random change in idle rpm
    By 4agze-hachisaurus in forum Technical - Questions
    Last Post: 21st April 2006, 06:02 PM
