Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 11 to 20 of 83
Thread: AE86 + EVO engine
  1. #11
    Mar 2006
    The single cam SOHC (that can be converted to DOHC) convertion is simple and it fits, there is also a 2.4 single cam engine that came off a L300 that bolts to the starion gearbox(although the twin cam head doesn't), twin cam is a different story.
    Going twin cam though there are issues with it (ie: more upfront expense) but i think it's it worth it.
    There are two ways of going twin cam:
    4g63 turbo off a vr4/evo, starion gearbox does not fit due to being a different bolt pattern, I have seen a supra gearbox used, all custom work....
    Or by using a starion block and gearbox with a twin cam head(timing cover and other parts are required).
    Unless using a late model evo engine, the turbo is going to be on the same side as the master cylinder and steering rack so there could be problems.....
    The only difference between the turbo and NA head's is the valve train's difference. So using the turbo cams in an n/a will work.
    Theres still a few things that I have to sort out, modifiying/replacing/removing balance shaft, upgrading cradle and what head studs should be used.
    Mattysshop: Check the avatar.
    Stuck: Drifting, going twin cam helps with the tuning side of things.
  2. #12
    Oldschool Member
    Jun 2006
    You should really do a write up in the Members Ride Section.. would totally pwn any other section.
    Keep up with the good work.
  3. #13
    Alex
    St Lucia
    I thought the early starions had 2lt leaded engines and the later ones were 2.4 unleaded but they both had simlar power because of emissions and stuff.
  4. #14
    Ferny Grove
    i'm confused, are you doing the starion/ twin cam head conversion now and putting a Evo motor in later?
  5. #15
    Mar 2006
    flamingheads: they came in 2.0 ltr here plain body
    In other country's theres a wide body with the heavier 2.6ltr featured in top gear once.
    Gilly: Eveything is similar if not the same it's still a 4g63t.... It's the same.
  6. #16
    Mar 2006
    Just the right amount of space for the crank angle sensor and water hose.
    For the gearbox, a small piece of the tunnel needs to be cut to fit.
    The factory crossmember that holds the gearbox in place, it's just a bolt on job.
  7. #17
    Ferny Grove
    cool, i don't know mitsu stuff at all.
    cool project.
  8. #18
    Oldschool Member
    Jun 2006
    Arent these cars 4WD? Does that make your AE86 4WD as well?
  9. #19
    Mar 2006
    Thanks, I didn't know much about this either until recently thanks to a few vr4 and starion owners.
  10. #20
    Mar 2006
    ^^Those engines still use FR engine layouts and 4wd distribution similar to a nissan gtr, they where used in rally from 1982 to 1986. 4wd domestic models are very rare.
  1. quick evo's
    By J0RD0 in forum Youtube Chan
    Last Post: 8th December 2010, 05:48 PM
  2. Replies: 9
    Last Post: 3rd September 2010, 07:49 PM
  3. 191kw 4g63 evo 2 engine
    Last Post: 1st September 2009, 07:26 PM
  4. Evo vs Bird
    By james86 in forum Toyotas in the Media
    Last Post: 4th March 2007, 12:48 AM
