Results 1 to 10 of 14
Thread: Dip stick blowing out
    Seth
    Guys I've just popped the hood to have a look at my engine. I took the car for a short bash, about 6500 in the reves max. The dip stick has pushed it self out. I all so noticed this the other day after taking my car for a fairly long run. I'm wondering if this is common. ( I dowwwt it) Do I have blow by issues. I should rev the car out to its max of 7500 to see if any oil come out.
    Any ideas from people who know would be good.
    Ian
    NOR
    pressure in the sump
    fit an oil catch can
    crank case pressure isnt getting a little high, prob due poor condition rings.
    can try an oil catch can, or simply secure ur dip stick down with a zip clip!
    ^^lol zip clip
    im sure its your rings man.
    what engine
    Site Supporter Javal's Avatar
    Josho
    Yus, crankcase pressure FTL. get your motor compression tested, see if its blowing smoke etc.
    if that turns up all peachy fit a coke bottle oil catch can, and fork out the whole $80c for a genuine toyota dipstick o-ring.
    Jul 2009
    nissan RB motors have this problem alot.. hey nathan.... hahaha..
    Seth
    How a catch can going to help. At the moment I've got the breather just venting into the engine bay. I hope its not the rings because this motor was supposted to have only 6 months of use befor I bought it since being rebuilt.
    Jul 2009
    try a compression test.. or a leak down test.. will tell you if it's the rings..
    dont worry matty, its just a nissan thing in general.
    cameron gales 'fresh' motor (rebuilt last week) didnt even last the entire super drift weekend in oran park, but the ol zip clip FTW truely works!
    well no not really, it then managed to blow oil between the sump instead
    did you already check to see if your pcv valve and your breather hoses aren't blocked and working ok?
  1. Get dipped! How to prep and dip your wheels.
    By motorculture in forum Zen Garage / illest
    Last Post: 15th November 2012, 02:40 PM
  2. WTB: [VIC] 20v front belts plastic cover & dip stick
    By LEVIN86 in forum Cars or Parts Wanted
    Last Post: 2nd May 2011, 09:30 PM
  3. 4age dip stick
    By TurboRA28 in forum Cars or Parts Wanted
    Last Post: 8th August 2010, 09:22 PM
  4. Sucking and blowing
    By AE86_4life in forum Technical - Questions
    Last Post: 5th March 2008, 09:37 PM
