Results 1 to 10 of 12
Thread: Wagon
    just thought id put up a story about my ke70 wagon that i baught about 6 months ago... got it for $700 with 6 months rego, it was a ugly peice of shit when i got it, still is but its a bit tidier and goes a bit better now.
    its got:
    standard 4k, rebuild 1km ago
    weber 36/36 carbie sealed up
    custom stainless steel carbie hat
    PWR silicon hoses here and there
    TDO4L on custom j-pipe
    compressed dobispord front springs
    resed rear leafs
    RPM heavy duty clutch kit
    PWR front mount intercooler
    2 1/4 - 3" intercooler piping
    2 1/4 dump pipe to below passanger foot well... exhaust system stops here, provides decent flame show
    Carter black 12 - 14 psi fuel pump (1000+ HP)
    Locked Standard Dizzy
    advanced timing
    ebay BOV
    resprey in Autoglym 'jet Black'
    1/2 respred interior in matte black
    woodgrain steering wheel
    sheepskin seat covers
    shit gear knob 4" tacho
    airhorns
    towl door trim
    battery relocated to boot
    fire extinguisher
    13x6 cheviot meshies front
    13x4ish stockos rear with re-treads
    AE82 front lip
    other stuff
    pics:
    how it was the day i got it:
    lowered and prime:
    paint finished:
    how it is now:
    engine bay:
    that is mad as, looks sweet from the front with the cooler peaking out. how much power is that setup making? Awesome job
    Veteran breno's Avatar
    Feb 2010
    Brendan
    Queensland
    Stafford
    Pfft, and Dave thought he was cool with his 4act.
    Never seen a turbo 4k before, what sorta power are you making?
    More info please!
    not making a great deal of power at the moment cos i only just finished it last weekend. its missing in higher revs at the moment, needs a dam good tune up yet but once that is done it should be decent... not sure on power figures dont really wanna guess cos ill be wrong. i mite get a dyno run in when its tuned then ill let you all know.
    more info...
    instead of daves 4act suck thru set up this is a blow through which allowes a cooler and a bov and maybe a bit more complicated dunno really tho cos havnt looked much into suck thru setups.
    for it to work the dizzy needs to be locked so it doesnt open out when revving high... if it does this then headgaskettes simply die. mine is locked with cable ties! apparantly using a electronic dizzy solves this problem tho.
    using blow thru the fuel pressure has to be at least 2psi above boost pressure... hence the carter black fuel pump. if its lower than boost psi then fuel will be blow back down the line and youll run out of fuel.
    another way of getting around this is using a rising rate carby-turbo fuel pressure reg and a efi fuel pump and lift pump setup. my fuel setup is basically just a way of avoiding the problem... hoping to get a reg soon tho. apart from advancing timiing thats pretty much all the engine mods that have to be done before itll work. also have to make sure air cant escape the carby by blocking/connecting all vaccum lines or you can put the carbie in a sealed box so there is equal pressure around the whole thing.
    thats about it really just did it cos i wanted to... doesnt cost too much, and a mate did the same thing who gave alot of advice and helped out heaps.
    Nat
    Newcastle
    Nice set up!
    What sort of front lip is that? It looks hot!
    its a AE82 front lip... the guy who i baught my daily (ae82 4age 16v) off had it but never put it on the car so he gave it to me. i have never seen another one i dont thing. eighter that or wen they came on the 82's there mounted so you cant notice them. anyways they fit a ke70 perfectly gives it a different look
    Nat
    Newcastle
    I'm totally scamming that idea man
    ha! fair enough a few probly will. i think maybe they come stock on around the 90 or 92 model sedans maybe... see if you can find one at the wrecker and let us know!
    Nat
    Newcastle
    I'm going to the wreckers tomorrow, so I will have a dig around and let you know
    Nat
    Newcastle
    Had a scout around, I think it might be a Streeter by Streeter front lip for an ae82
  1. The Wagon
    By Konakid in forum Other Toyotas
    Last Post: 2nd March 2016, 07:04 PM
  2. GT LEGACY WAGON 1990 (Not my GT wagon selling for a mate)
    By GT-LEGACY-GT in forum Cars for Sale (Not Toyotas)
    Last Post: 21st August 2009, 04:01 PM
  3. ke70 station wagon or corona station wagon
    By Trucka 115 in forum Cars or Parts Wanted
    Last Post: 14th July 2008, 05:24 PM
  4. I NEED A WAGON
    By Arch in forum General Topics (No Technical Questions)
    Last Post: 20th March 2008, 10:04 PM
  5. New wagon
    By Joshz18 in forum KE70 / AE71 Owners Forums
    Last Post: 5th September 2006, 01:52 PM
