1. controlled by computer - yep can be controlled by microtech
2. on the front left hand side (from rear) of the engine head
3. try club4age.com
Currently doing a blacktop 20v conversion in a mates car and was wondering if...
1. is the VVT controlled and actuated by oil pressure, or does the ECU have some part in this, and can this be controlled with a microtech?
2.where is the switch for the vvt, be it ether electrical or oil pressure driven?
3. does anyone have a ecu pin wiring diagram for the blacktop motor?
3. try club4age.com
you mean on the front of the engine, just under the front of the exhaust cam?
i also noticed that it has 2 oil pressure switches, well that's what they look like.. one is, just at the front of the block on the exhaust side, and one under the throttle bodies, in the centre of the block
one on the exhaust side s for you vvt yo!
one under the throttles is a knock sensor from memory
1. Actuated by oil pressure and switched by the ECU, the silver and blacks are slightly different.
2. It sticks out ths side of the head I believe. Have just been researching this for other reasons. Bilzilla's website covers this in detail and was very helpful. All makes sense now!
3. Yes they are on club 4AG
