Results 1 to 6 of 6
Thread: axle adjustment
    Default axle adjustment
    The gap between the drivers side is so small that you cant get your fingers between the tire and the arch and the gap is huge on the other side. How do i move it over? Someone told me there is a way of doing it???
    BTW, the wheels are the same width.
    Jonathan
    Mark
    you buy one of these,
    then send it to me and the problem should be fixed!
    Oldschool Member
    Mar 2005
    Roy
    Bris
    As said, buy a panhard rod. Easy fix.
    Whitchy
    Central Coast
    Visit bunnings and buy a few washers that will fit over your wheel studs then space that shit out!
    Veteran johl's Avatar
    Johl
    ^^^^^ lol +1
  1. 4 link adjustment
    By bigm in forum Technical - Questions
    Last Post: 25th March 2009, 01:37 PM
  2. TPS Adjustment
    By TruenoCoupe in forum Technical - Articles
    Last Post: 28th July 2008, 01:03 PM
  3. Valve adjustment 4K-C
    By Ksevn-T in forum Technical - Questions
    Last Post: 19th May 2008, 01:30 AM
  4. KE70 clutch adjustment??
    By shinny in forum Technical - Questions
    Last Post: 17th June 2007, 05:55 PM
  5. Clutch pedal adjustment
    By Skein in forum Technical - Questions
    Last Post: 8th September 2006, 11:06 AM
