Results 1 to 10 of 12
Thread: falcon AU springs
    Senior Member 45aken's Avatar
    Marko
    Default falcon AU springs
    Just wondering about these springs.
    Are they the same diameter size as ae86 springs?
    And are they 6kg/mm?
    In other words is there anything dodgey about putting these in the back?
    Veteran Konakid's Avatar
    Henry
    Eastern
    in the rear depending on how much you cut they are around 3~4 kilo.
    Marko
    Thats pretty shit, lousy progressive rate springs.
    why do i keep hearing 6kg then?
    Dave
    cause the internet is full of rubbish information?
    they arent progressive rate....
    the rate will be determined on how much you cut them, its the same with ANY spring (a spring is just metal.....)
    i have them in the back for my car, no idea on the rate, but they seem to be pretty well matched with the 8kg (i def know they are 8) in the front.
    also if you get springs from one of those bigger falcons, fiarmont/LTD type things the springs will be stiffer again.
    you cant expect exact information on the spring rate, since knowone knows how much they are to start with, and everyone cuts them at different lengths.
    i got mine for like 10$/pair, best off getting some, cutting them, and see if you like them!
    Senior Member adam's Avatar
    Adam
    There's calculators you can find on the net which calculate spring rates. You'll need wire diameter, coil diameter, etc.
    I calculated mine and it worked out to be around 6.5kg/mm.
    Marko
    haha tell me about it.
    yeah im not after exact information, but from 6kg down to 3kg is a bit of a difference.
    was just going to get a few and test some ideas out, I am aware of spring mechanics, just dont have one infront of me to work out the rate.
    Marko
    did you count the bottom and top coil as free? (the seats)
    Adam
    The calculator only ask for 'active coils', so I put in how many I had. The bottom coil and I think a quarter of the top coil was thought of as 'inactive' coils.
    Marko
    Yeah sweet,
    should be from where the coil at the bottom lifts off the seat to the same at the top.
    Henry
    Eastern
    They differ between falcon models but in a stock falcon (not LTD/fairlane) they are no stiffer than 4.5kg at about 3 inches lower than stock.
    I had LTD ones in the front of my car at one stage and they felt like about 5kg.
  1. Looking to buy: AU FALCON SPRINGS
    By x744 in forum Cars or Parts Wanted
    Last Post: 17th September 2012, 10:58 PM
  2. Wanted: Falcon ute - AU or later
    By maxhag in forum Cars or Parts Wanted
    Last Post: 7th November 2009, 05:09 PM
  3. au falcon springs for ke70 or ae86
    By fatke in forum Car Parts For Sale
    Last Post: 4th September 2009, 04:57 PM
  4. ae86 bumper for ke70 au falcon springs
    Last Post: 3rd June 2009, 11:56 PM
  5. WTB:: Sierria front shocks and cut au falcon springs.
    By gumbie in forum Cars or Parts Wanted
    Last Post: 8th September 2008, 03:46 PM
