it will be 65 N/mm, which is 6.6 kg/mm if my calculations are correct.
oops! greenline had me confused, the 65 does indeed mean 6.5 kg/mm. TRD state their rates in N/mm, but the part number tells you what it is in kg/mm
I've got a part number here on a TRD rear spring. 48231-AE801-65.... Does anyone know if I am right in guessing that the 65 at the end means it is a 6.5kg spring?
Cheers guys
Nafe
ahhh I see, thank you sir
