Results 1 to 10 of 12
Thread: BT igniter and coils
    Member dodgybrooks's Avatar
    Stephen
    Townsville
    Default BT igniter and coils
    Put my 20v in yesterday and realised that I forgot to claim the igniter and coil setup from the donor car before it got crushed. I checked today and Toyota have a couple of each in stock in Melbourne but they want genuine part (read: genuinely expensive) prices for them. I asked the parts guy at Toyota and he said that the same setup "may" have come out on the Hilux, can anyone confirm this? I wanna try and find some at the wreckers, so if anyone knows what other cars shared them tell me!! Or if anyone has gone aftermarket management and wants to get rid of theirs then sell them to me!!
    Part numbers are
    Ignitor 8962112050
    Coil 9091902197
    Nathan
    Lilydale
    hey mate,
    i have a coil and ignitor if you need them, they are from a silvertop though, i will check part numbers when i get down to the factory they are at, and let u know.
    nath
    Stephen
    Townsville
    Wicked. Yea check those numbers and hook a bloke up.
    Jonathan
    Silver top is the same.
    I happen to have in my hand, a spare coil and igniter:
    Coil 90919-02197
    Ignitor 89620-35300
    Both from a 22R carby HiLux from memory, setup to run off a mechanical advance/electronic dizzy. You have to double check with Anthony to see if this igniter will work for you.
    Senior Member rallystanza's Avatar
    Jeremy
    Vic
    Straya
    I have a spare coil from a blacktop but it doesnt mean jack. I used an aftermarket bosch electronic coil and it all works fine.
    Stephen
    Townsville
    Quote Originally Posted by rallystanza View Post
    What did it cost you and what are the part numbers?
    Anthony
    yeah you can use almost any coil, but coil leads can be tricky with 20Vs. igniter has to be the right one really. the IGF signal changes style/shape a bit through the years and if you dont match it up you can get some running issues.
    Jonathan
    Your 20v coil is the same as on:
    SW20
    JZA80
    SXV10
    most HiLux
    Lexus 1UZ
    Your igniter is the same as:
    LS400 1UZ (2 are used)
    and a bunch of similar vehicles as listed above
    You just have to walk around the wrecking yard.
    Anthony
    well its not quite as simple as that. I can tell you for instance that SW20 changes connector shape AND igf style through its lifetime on the ignter as well as coil plug and retainer clip shape on the coil sode of things., at the very least between gen 2 and gen 3. 1uz does similar things as well.
    that list is a good starting point though just make sure you have a sample, dont just order over the phone, you may be disapointed.
    Nathan
    Lilydale
    im sending him the factory 20v coil and ignitor tommorow.
    are you sure 1uz are so different? the 20v coil and ignitor plugged straight into a friends 1uz.... Exacly the same. there may of course be different types for different year motors. this was a 93.
  1. 1NZ/1ZZ coils and 20V motors/igniter/coils
    By 70XIN in forum Technical - Questions
    Last Post: 24th March 2020, 07:44 PM
  2. Microtech lt10s with igniter and coils Bris
    By toyotakraze in forum Car Parts For Sale
    Last Post: 27th September 2010, 08:16 PM
  3. Ae92 4agze twin coils leads and igniter (Briz)
    Last Post: 26th July 2010, 06:26 PM
  4. Duel igniter - Can it run 4 coils?
    By Jonny Rochester in forum Technical - Questions
    Last Post: 31st August 2009, 10:58 PM
  5. igniter wires ?
    By loc33e in forum Technical - Questions
    Last Post: 2nd May 2008, 11:32 PM
