Results 1 to 10 of 14
Thread: Setting the timing and cas
    Senior Member slideways's Avatar
    Tristan
    Default Setting the timing and cas
    okey dokey.....
    just put the head of my motor back on, set #1 to tdc
    and the timing mark on the harmonic balancer doesnt corelate to the 0 degree mark, instead it sits at about 20 ish. and there is only one mark.
    and when installing the cas, eeeeerrrr..... how do you do it?
    I got the back cover of the cas off, and the button thingy lines up with the top contact.
    Jonathan
    Timing belt is on wrong.
    Tristan
    wrong hey? where did i go wrong?
    the gears line up with there marks, and the motor is set at tdc?
    Is the cas set right?
    oh yeah and we set tdc with the head off, kept it there and re-checked it was still on tdc
    Anthony
    how did you set it to TDC if not with the timing mark on the pulley?
    Tristan
    Quote Originally Posted by Anthony View Post
    Me and my mate a mechanic, set it it to tdc with head off and noted the timing mark in the pulley was off. and the we used a SST screwdriver down the plug hole to find tdc again. The mark on the HB lines up with the 20 mark on the plastic back cover thing?????
    Anthony
    using a ze crank pulley by chance?
    Jonathan
    The key on the crank keyway is missing.
    Jonathan
    Oh yeah, probably an old MR2 motor. WIth the needle thing.
    Tristan
    Yes, Yes I am. I get the feeling by your question this is something worth mentioning?
    But can anyone give me instruction on installing the cas.
    can only find instruction on a dizzy, which is a tiny little different
    Jonathan
    When on TDC, the mark on the crank is ment to line up with a pin sticking out of the oil pump, which is close to 12 o'clock I think. You probably swapped the black plastic cover with another motor.
  1. Setting timing without marks on crank pulley
    By geoff in forum Technical - Questions
    Last Post: 15th February 2012, 12:14 AM
  2. 4agze cas timing
    By joe81 in forum Technical - Questions
    Last Post: 22nd November 2011, 05:25 AM
  3. setting up my suspension please HELP
    By ae86-13b in forum Technical - Questions
    Last Post: 12th November 2009, 05:29 PM
  4. setting valve timing on 4a SOHC - help needed
    By Maxhag in forum Technical - Questions
    Last Post: 13th January 2008, 03:11 PM
  5. 4AGZE/GTE Timing setting
    By AE71 Rolla in forum Technical - Questions
    Last Post: 29th September 2007, 07:49 PM
