<div class='quotetop'>QUOTE (741 @ Sep 26 2007, 03:27 PM) </div>It looks like the discs mount to the back of the hub because you can just see the edge of the hub and then it steps down to the bolt on spacer.
FC rear calipers do have the handbrake on the caliper.
Remember when doing rear disc conversions and master cylinder swaps etc to find out where your inline residual line valve is for the rear drums and remove it. Rear discs dont need some pressure on them like drums do.
I was talking to Hen about this on the weekend and he was under the impression that some of the rally guys were running a magna disk with the rx7 calipers, all under 14"s.
Chris.
[/b][/quote]
hi.
did you happen to catch what magna rotors hen sad they were using? Ive got the same fc ally brackets and some civic type R rotors, although i havent tried to fit them under 14's, wouldn't be bad to know what part number to get if they dont
<div class='quotetop'>QUOTE (mc68 @ Nov 29 2007, 12:39 AM) </div>
Hen didn't know the model that the rotors came off and just suggested that I get in contact with the guys. I believe it was Gillie from Toymods.
Thanks mate. I can chase it up. I was just curious and will, if/when I get the time, compare the dimensions to the civic disk to see what the differences are interms of both the disks and thus the brackets required.
<div class='quotetop'>QUOTE (Benny @ Dec 23 2007, 01:53 AM) </div>wat model rotors are u planning on buying?? EG civic?? do project mu or endless make rotors to suit EG civic?? personal opinion says overkill, but if u have money to burn and like ur brand name bits go for it
