If anyone decides to get brackets made up I would be very insterested in a set as well. I will looking at maybe getting some made up but it wont be for a little while yet as I have other priorities on the car at the moment.
In regards to the rotor mods, if you found a place that could machine the brackets, they would have a lathe and could do the chamfer on the rotor.
The guys at work did the brackets as a one off for me, they can't easily make any more.
Maybe try yellow pages to find an engineering or machining shop that can do this kinda thing for you.
Hay dude sweet tech info could u pm me the dimensioned CAD drawings????
let us know how the R32 master goes 2 do u have a part number for it ect??
S13, R32, 33 and 34 2 port master work (can't remeber whether thats ABS or not) they bolt up to the 86 booster, just need solid lines made to suit
With R32 (non-ABS) master, all lines fit, the front driver's is tight though, and could do with a new, slightly longer one.
I suspect this would also be true for the other masters listed above, but cant confirm.
r32 NA or gtst?
I have ordered R32 GTS-T Non-ABS, hopefully getting here today or tomorrow.
From what I have heard like Hen said should be a little tight but will fit with standard lines.
I got one from a GTS-t, never checked if NA is the same.
20V, where are you ordering one from? I heard Nissan no longer stocked them.
Could you email me the CAD drawings mate? Email addy is pugzor(at)pugzor(dot)net. I can repost them on my website if anyone wants them, or if it makes it easier for you rather than sending them to anyone who wants them?
Hey
Zip file with CAD Drawings is located here:
You will need AutoCad 2000 or newer to view the files.
I got the R32 GTS-T Non ABS Master cylinder from Autotech Imports in Adelaide.
They had a listing for an R33 Item on eBay, but after an email they sourced an R32 model.
Its obviously a used item, but I will try and re-seal it. It cost me $80 shipped.
Oly
