Hi Oly
How did you go with your master cyclinder ?? Is it working ok and any pics of it fitted up ?
Cheers Craig
There is also an R32 Master Cylinder available in Capalaba, QLD if someone more local is after one.
Cresta Australia is the place, Japanese Parts/Cuts Importers, guy said about $85. (07) 3245 1555
Oly
Hi Oly
Cheers Craig
Contact No: 0408998795
EMAIL: justjdmimports@bigpond.com
LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
Grrr, been to busy and unorganised to give it a good go.
Will be working on car over the Christmas break, will get it fitted up then. Will upload some photos after its done too.
Cheers,
Oly
heh, got my kit from jland today...im happy with that calipers are in top condish too!..i dont even have to get them rebuilt :\
pretty good bang considering it was only 670 odd too my door.
..just continuing on from this - I can get brackets made up pretty cheaply(<$300 pr) if its possible to have them cut out of 2 x 10mm plates and welded together. (have a mate who works for a laser cutting mob).
I'm going to pull my struts off this weekend and see what I can come up with - in the meantime does anyone have any ideas if this is possible? The CAD drawings posted above have the material thicknesses at 9mm and 11mm if it were made up from two plates welded together.
Could these be made from mild steel or will there be issues?
Mild Steel would be fine, that is what my plates are milled from.
Also, the 2 plates welded idea is also a good one. The original plates that "Twinky" from Toymods made were 2 separate items that were doweled then welded together.
I've seen master cylinders with 2 outlets and 3 outlets, I'm assuming you only need the 2 outlet master? Whats the 3rd outlet for?
3rd outlet is probably for left/right front brakes. Means you can get rid of the factory splitter on the firewall.
Eddie.
I once created a CAD design of one of these adapters. I reckon someone who I did if for may be/or sent it to Twinky!
I should've patented it!
AE86 4AGE "Slowly but surely"
