Thanks for that taylz.
I can run 15x8s so fc brakes are fine.....
So is anyone making up brackets?
bass_2000_au_au@hotmail.com says:
they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
Ill most probably end up getting one offs through work as we do alot of brake upgrades.
When it comes to the time when i need them i will post up a thread asking if anyone else wants/needs them
Hey Craig,
If you remember can you send me a PM when you're ready to do this. I'm planning to have these fitted by the beginning of December, so if that fits with your schedule I'll definitely be in for a group job.
Regards,
Im hoping my car will be on the road at the end of december so hoepfull it will before then
I've got a pair of those very same mazda adapters on my table. Copies will be available in a couple of weeks if all goes well. I just don't have a spare set of hubs atm to dummy fit and modify the bracket to suit a cheaper rotor option than the honda one.
will you have brackets made to run a slip-over hub FC rotor with FC caliper?
I'd prefer to make it mate up the the back of the hub. I just need to bolt the adapters to some struts and calculate the height of the needed rotor. I've converted got the DBA catalogue to a database so I can make a list of exact fits.
Before i get mine made up i will also be working on using RX7 S4 rears aswell. According to the online DBA catalogue they use a 273mm daimeter rotor, 20mm thick.
I will be setting it up on an Fseries diff though.
this's my rx7 caliper.
i got the adapter made by Japaneses. anyone interested pm me.
