Results 1 to 10 of 10
Thread: 4kc Engine Modifications
    Default 4kc Engine Modifications
    Hey guys wanna get some power out of a 4k.
    What will a rebuild cost me in parts roughly?
    Also what type of mods to get a bit of power out of one?
    Carbs?
    Cheers fellas
    Jonathan
    Basically, any carby you find will be bigger than the stock 4K one and an upgrade. As a very cheap starting point, a Corona 18R carby fits.
    3K motors used to be used in Formula race cars, so look into that. Twin sidedrafts.
    Nathan
    Lilydale
    i beleive by putting a 3k head on can be an improvment. i think it bumps up the compression.
    but what i would look for is an old liteace or townace(i think) these sometimes have a 5k engine.
    Veteran anastasios's Avatar
    Taz
    Earlwood
    yea if your going to rebuild and modify a k series engine then either go 5k or 7k, depends on your budget mainly
    Alex
    Wagga Wagga
    5k, shave head, new cam, carby(s), extractors and exhaust. Should be enough for a fun K series. Though, the cost of doing that and getting it tuned, would nearly be easier to just go 4age.
    cheers fellas
    is it possible to put a Toyota corona engine 18rc 2litre engine in a ke still using stock box mounts etc?
    Jonathan
    Not a good idea. Try a 3T.
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    I have a mild cam, 5K carb, shaved head, stiffer valve springs and possible light porting on my 4K.
    Goes decent for a little 1.3L, I quite like it.
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by AE86R View Post
    I haven't seen this done.
    Quote Originally Posted by Jonny Rochester View Post
    This i have seen done. From memory, it was TA22 mount brackets, hybrid TA22/KE70 rubber mounts on a KE crossmember. Not too hard.
    EDIT -
    AE86R - if you are just suggesting the 18rc from a corona because you have one available - if it's from an RT132 / RT133 - I want the mounts.
  1. what is this? 4kc engine bay
    Last Post: 21st March 2011, 09:38 PM
  2. Replies: 5
    Last Post: 17th April 2009, 12:47 AM
  3. 4kc Modifications
    By AE86R in forum Technical - Questions
    Last Post: 11th March 2009, 06:40 AM
  4. Modifications/Engeneering
    By ADICTD2BASS in forum Technical - Questions
    Last Post: 7th January 2008, 05:28 PM
